Josh-Abram
Vehicle Specs (factory):
2014 Toyota Tacoma SR5 (Metallic Grey) Access cab 6ft bed
4.0L V-6 Gasoline Engine Auto transmission
106,000 Miles
Asking $50,000
Suspension and drive:
Old Man Emu adjustable BP-51's w/ Dobinson 800lb constant load leaf pack, Dobinson UCA w/ Timbren offroad bump stops (front and rear)
ECGS 4.56 gears Rear ARB locker
CVJ front axles 9808 TR (lifted – moderate angles)
Power Brakes (grey)
Wheels and tires
Five - 17” Method 701 (black
Five - 285 70R17 Toyo AT3 Tires
(cab mount chop with Total chaos plates)
Recovery and Armor
Pelfreybilt Front bumper with XO2 10k winch
Factor 55 fairlead with Flatlink (grey)
C4 Fab Overland Rear bumper
RCI sliders and Aluminum Skid plates
ARB twin compressor, manifold and locker solenoid with Slee mounting bracket
On-Board Electrical and accessories
Juniper side by side Dual Battery system with Red-Arc 1225D charger (2 Group 25 Full Throttle Batteries installed 4 months ago)
110-watt Lensun semi flexible solar panel
Switch pro mounted on power tray with blue sea 6 circuit fuse box and ground block
20” Rigid light bar, Baja amber squadrons (fogs), Rigid D series pro (rear bumper)
Goose-gear electrical panel in camper with blue sea fuse panel, below deck panel, and Propex heater/thermostat. Victron BMS
Living Quarters (vehicle interior)
Goose-gear in cab rear seat delete (full length)
Alu-Cab Canopy camper with Full options (Standard Unit includes the following: (5) National Luna Dual Color LED Lights (Red+White), Two Dual USB/12v Chargers and Stalk Lights near bed platform, CHMSL, Solar Pre-Wire (Includes Anderson SB50 Plug Mounted On Roof)
Options included: Shadow awning, Shower Cube, mozzie nets, GP drop down table, GP side window, Table with slide, rear mole plates, spare tire carrier, Canvas storage bags back door bulkhead and sides, 1450mm load bars, expedition essentials 2 board Maxtrax holder, 11lb propane tank and AT mount. Custom built propane lines for heater.
Full goose-gear cabinetry driver side front and rear utility cabinets, passenger side front utility cabinet with rear double drawer module.
Propex heater with digital thermostat on electrical panel.
12-gallon custom water tank on front lower bulkhead with 12-volt pump and shower head.
60L National Luna dual zone fridge with baseplate
Additional parts
Prinsu Roof Rack
Pedal Commander
Raingler nets - Tacoma Attic
Safari Snorkel with Cyclone pre filter
Have more photos I can send. Located in Denver if you want to see it in person.
106,000 Miles
Asking $50,000
Power Brakes (grey)
Wheels and tires
Recovery and Armor
Additional parts
Prinsu Roof Rack
Pedal Commander
