2018 Ram 2500 Laramie 6.7 AEV Prospector XL clone w/MITS Flatbed & FWC Hawk Flatbed camper
KG007
2018 Ram 2500 Crew Laramie 6.7 Turbo Diesel AEV Prospector XL clone w/MITS Flatbed & FWC Hawk Flatbed camper
Just finished Build (Oct.of 2025 to Jan. 2026) Less then 3k on build
Overland bound ready for any off grid living traveling scenario.....
-Over $172k in build
-Located in Portland, Oregon Listed at $135k reasonable offers acknowledged, FWC Flatbed camper avail separately too
I have built this rig to be long term, low maintenance. highly dependable overland live in ready beast
2018 Ram 2500 Crew Laramie (Heated and A/C dual power seats, Heated steering wheel, 8.4" Screen w/ Carplay, Keyless Entry and Keyless Go, Auto Remote Start,
Engine block heater, Off-Road pkg (Hill decent control)
I am the 2nd owner (Local Oregon vehicle since new, NO Accidents, Non Smokers, NO Pets
ONLY 77k Miles
The 6.7 CUMMINS has had all the prone to unreliable issues removed, making it a dependable 1million mile engine
-EGR removal and delete kit custom mounting points for EGR Delete brackets
-Throttle valve delete kit
-Exhaust removal from turbo back and install of new high flow deleted system exhaust with high heat painted rear tip in black.
-Electrical connection block off kit
-ECU tune with map switch
-New transmission oil with filters
-New transmission fluid thermostat unit.
-New bushings in front track bar
-New coolant expansion tank and lower hose
-Banks Killer Grid heater Upgrade
-Banks Ram-Air Intake
-ARB Rear Air Locker
-ARB Dual Compressor (under hood)
-YUKON 4.10 Gears
-Titan 52gl upgraded fuel tank
-WARN 16.5tiS winch with remote
AEV PROSPECTOR XL (clone)
-AEV DualSport XP Suspension (AEV/Bilstein XP8100 Reservoir Shocks)
The AEV 3-inch DualSport XP Suspension Lift Kit for 2013-2018 Dodge Ram 2500 HD takes that same concept and elevates it to the next level by giving customers an even broader spectrum of dampening performance for better performance, more control, and improved consistency at higher speeds and over rough terrain. This is the perfect suspension for HD Ram owners who take adventure travel seriously
-AEV HighMark front fender flares
-AEV Front Bumper with Stinger
-AEV Procal SNAP
-AEV Katla Wheels 17"
-AEV Intercooler skid plate
-AEV Rear mudflaps
-BF Goodrich KO3 All Terrain T/A 39x13.50R17 Tires
I picked these over M/Ts for several reasons:
A much smoother quieter road tire
Amazing in wet and snow conditions (3 Peak Rated) for those winter overlanders, no need to chain up
Tread warranty of 50k miles
LIGHTING
-MORIMOTO XB Headlights
Double Bi-LED setup, these headlights deliver a well-defined beam pattern with impressive width and intensity, ensuring superior road illumination. They are DOT-approved, exceeding all safety regulations, and come with integrated adjusters for easy aiming. Installation is a breeze with their plug-and-play design, and there's no need to worry about error codes or flickering. The Morimoto XB LED headlights also feature a striking sequential LED daytime running light and turn signal function, making your truck not only safer but more visually appealing. Built to last, these headlights boast a UV-coated polycarbonate lens, lightweight PPS plastic housing, and efficient aluminum heat-sinks.
-4x VisionX 6.7 CG2 Multi LED Light Cannon Lights on Bumper (2 in White/clear, 2 in Selective Yellow) total of 54,000 Lumens
-2x VisionX 6.5 LED light Cannon Fog Lights by AEV flush mounted into AEV Bumper (5000 Lumens each, 2500ft spot lens beam
-2x VisionX CR-7 Spot Beam Driving Ditch Lights (Massive 7,665 Lumens each out of a 4.5" housing)
-SDHQ Build A-Pillar Light Mounts (Ditch light brackets for the VisionX CR-7s)
-Auxbeam AR-800 RGB switch control panel *Bluetooth app (color matched blue to factory switches)
All VisionX lights, ARB Compressor, ARB Locker are setup through control panel and available on phone app via bluetooth
-Expedition One Mule Ultra Roof Rack
-AMP Research PowerStep XL (Powered running boards)
-GMRS Radio Ready (Antenna and wiring to inside cab, ready for GMRS radio
-Custom Black to Vinyl Hood and Rocker panels
-XPel XR Ceramic tint on all windows
2025 MITs Alloy flatbed (Aluminum flatbed from Australia)
-Custom Painted White to match Ram
-Line-X custom sprayed bed top of flatbed
-Only 625lbs, 8 gallon Headboard water tank, 5ft rear under tray drawer, flared mudguards, Front and Rear under tray toolboxes, textured powder coated
2023 FWC hawk flatbed camper was Factory dealer demo and Installed late 2025
This FWC Hawk is SUPER LOADED with a $70k MSRP over $10k in additional dealer installed Upgrades
Below is the full list of factory and Upgraded options/features
-Upgraded custom installed Truma VarioHeat Furnace
-REDARC Manager Alpha 75 with REDVISION Display (bluetooth app control too)
-REDARC TVMS Rogue
-3 Dakota Lithium 135ah Heated Batteries
-REDARC 2000w Inverter w/ Outlets Located Under Dinette Seating
-USB-C / USB-A Outlets Added @ Kitchen Counter
-USB-C / USB-A Outlets Added @ Battery Box
-USB-C / USB-A Outlets Added @ Outside Near Awning
-300w of Sunflare Blox Mounted on the Roof
-Exterior 12v Ports for Powering Other Accessories in Vehicle from Camper Power System.
-Relocated Water Heater Control Panel
-All electrical wiring has been upgraded
-Magnetic Light Blocking Fan Covers
Loaded factory options
-Interior: Peyton Granite Fabric
-Metallic Charcoal Exterior
-Flushmount Sink & Stove
-85L Refrigerator
-Water Heater with Inside & Outside Shower
-Built-in Cassette Toilet
-Queen to King Bed Slide
-Dual Powered (with remotes) Roof fans
-8' Fiamma Awning
-6 Step Torklift Glowstep Stairs
-Rear Flood Lights
-Exterior LED Lighting
-Aluminum Rear Rack (custom powder coated black)
-New Style Thermal Pack Upper & Lower
-Carpet Kit (Covers Flooring)
-Water Tank Cushion
-Internal (power with remote) Roof Lift Actuator
Standard Options
-Rear Dinette Seating
-20 Gal Fresh Water Tank
-Underbed Storage
-Gas Strut Lift Assist
-Exterior Solar Port for Portable Solar
-120v Shore Power Connection
-12v Vehicle Charging
-2x 10lb Propane Tanks
-LED Interior Lights & Porch Lights
-Privacy Curtains
-All Aluminum "Flex Frame"
-Insulated Side Walls & Roof Rugged Pop-UP Liner w/ 4 Windows
-Fire Extinguisher, LP/CO Detector, Smoke Detector
Contact info
kevinjgordon@icloud.com
Tel: 503-970-1008
I have about 25 more pics and video available
Nice build. I already have a 21 6.7 flatbed hawk build - but if I didn’t I’d be giving this one a look.
For anyone wondering who isn’t familiar with these sorts of builds they are quite capable, roomy, and the 6.7 never wants for power. $135k is a good price for what this build is. I have $240k in mine and this one is hitting a lot of the same high points.
MOLLYmaz
