2020 Crux 1610 Salt Lake City
tullydog
$14,000 With the Bundutop $12,000 without
CRUX 1610 Independent, Trailing-Arm style Coil-Sprung Suspension system includes heavy-duty spring rates and gas charged shocks to comfortably and confidently carry all of your equipment and gear. Crux 1610 rolls on beefy 31" Cooper All Terrain Tires mounted on 15" alloy wheels and even includes a matching spare! And with 25" of ground clearance, you can be sure that the CRUX 1610 will roll up and over anything your vehicle can.
CONNECTIONS
CRUX 1610 includes 2 - AMG batteries powering a 2000 watt inverter with numerous 12v and 110v plugs. CRUX 1610 also features LED lighting throughout the trailer.
SUSPENSION, WHEELS AND TIRES
CONNECTIONS
1610 Specifications
Feature
Details
Trailer dimensions
L 11’6” x W 5’5” x H 4’9”
Tongue Weight
120lbs
GVWR
3,300lbs
Suspension
Independent suspension with heavy duty springs and gas charged shocks
Brakes
10” electric brakes with a hand brake on the draw bar
Safety chains
Dual drawbar safety chains
Chassis
Heavy duty, off-road, galvanized steel frame
Rims and tires
15” alloy rims, six bolt pattern and 31” x 10.5” Cooper Tires
Connection Plug
Standard 7-pin connection plug
Water Tank
Stainless Steel 15 Gallons with alloy skid plate
Storage
All storage doors have air-tight, waterproof seals and locks
Jerry Cans
Two jerry can holders on drawbar
Stabilizer Legs
Four heavy duty, adjustable, lockable legs
Lights
LED lights throughout trailer, in crucial locations: chef’s galley, electrical panel, refridgeration chamber, LED tail lights
Bed Size
L7’1” x W5’7”
Electrical
Two AMG deep cycle batteries, overload protection, four 110V outlets, two 12V outlets, 2000w inverter. Battery is charged by your vehicle when 7 pin style plug is connected. Shore power and wired for Zamp solar power.
Coupler
360 degree poly block coupling
Trailer Jack
Heavy Duty Swing Up 10 inch Jockey wheel
Roof
Roof rack with gas lifting shocks
Chef’s Galley
Slide out stainless kitchen with Dometic two burner propane stove, sink and electric water pump.
This has been a great trailer and we have enjoyed the ease and versatility of the unit. I built a custom rack and mounted a Bundutop electric deployed roof top tent that reduced weight and increased ease of set up.
tullydog
Salt Lake City
tullydog
specific images available upon request
tullydog
It’s a standard 82”x 56” I believe and yes we have had wind pick up and it’s very solid, the tension from the mechanism pulls it taught and creates a very stout shelter.
Arcadia1415
