2020+ Frontier
Frontier has a 9 speed transmission
What's the axle gearing? Rear LSD or locker?
I don't recall with the final drive is for the D41 or D40 with the 9 speed. I know for the D40 with the 5 speed Pro-4X has a 3.36. Pro-4X has an E-Locker from the Factory and it can only be activated in 4LO(then again you don't want it in 4HI).
I'm going to say it's relatively close to that. That's assuming you keep it stock. Put certain modifications on there and it's going to change those modifications will include but are not limited to, bigger tires, aftermarket front bumper, lift kits, and anything that might be on the roof.
For me running a D40 with the old Powertrain I have quite a few different modifications and if I just run 87 octane I can usually see anywhere from 14 to 17 MPG depending on the conditions. With premium (91 and up) I can see anywhere from 15 to 20 MPG depending on my conditions.
Good info thanks
I need to take my daughter to go test drive one, the legroom in the backseat is the only concerning factor for her and other passengers
I just don't need a full-size truck anymore and am look for something with better fuel economy and lower miles than my Silverado (now at 120,000)......since I am traveling alot more for work
Specs compared for mileage
Dimensions compared without the Turbo Max motor
Specs and dimensions with 2023 models, 4WD and the Turbo Max motor
I just don't need a full-size truck anymore and am look for something with better fuel economy...
The Frontier gets about the same MPG as the F150 with 2.7 (~18.5). The Ranger is ~20, the Tacoma ~19.
If fuel economy is important, do you need a truck or would a different vehicle work?
5mouse
