2022 OBI Dweller 15 no manual need startup help
longbowelk
I'm new to this forum. Not new to RVs but just purchased a new 2022 OBI Dweller 15 from a dealer that didn't know much about it. There is not really a manual just some super fine print brochures on it. I am totally new to off grid solar panel, etc. I'm wondering if there might be an obscure youtube on basic info, general maintenance, etc.
Also, any info on best way to add portable solar panels when camping in the shade.
I have an OBi Dweller 15. There is a 50 AMP Anderson port at the tongue of the trailer that you can connect an external solar panel to. Be advised that (at least on my trailer) this is a direct connection to the battery, not to the onboard solar charger, so you will need to use some other charge controller. Personally, I changed this setup and wired that connection and the onboard panels to a better MPPT charger.
M meadow build
