its like $36 for a 40A buck, just do it right.. its cheaper in the long run.
My Engel Runs off 24v, my inverter could had, my solar chargers will all do 24v, no shortage of air compressors either in 24v.. the only things I'd need a 12v circuit for my rig is running the Propex, Power Vent, USB Chargers and LED Lighting.. 10A of 12V would do me fine if I moved the big AC loads to 24v.. and the 24v inverters usually eek out higher efficiency than their 12v variants.. at some point you reach a threshold where they stop really doing much in 12V for inverters.. by the time you get to 2000-3000VA all the good quality ones are 24v/48v and all thats left is cheap chinese units that are terribly inefficient.. there's a good reason for that, the losses over the cabling even on short runs starts becoming unacceptable.
