2nd Mitsubishi, first major problem
clmrt
After farting around on RockAutuo and getting everything in the basket, I couldn't do better than $200 +/-. Ima bite the bullet and just let Mitsu do their thing, I know it's a big chunk, but they've treated me right and I want to maintain a good relationship with them.
dieseltechJay
It'll be worth it. Parts will be Denso or NGK which are OEM suppliers.
clmrt
I keep forgetting to update with prices and numbers.
Next issue popped up at our 75k service - Bad rear driver's side hub. Audible as a squeak when braking, and as a clunk when shaking the wheel by hand.
$650, under warranty. RockAuto lists the part for $125.
More to come...
jeep-N-montero
More to come...
I guess it's a good thing you have that nifty warranty then.
clmrt
Another three months, another oil change.
Six hours before my appointment the transfer case threw up again, code 33. Dealer identified the switches again, 3 days out of Mitsu warranty and by miles as well, not sure how many. So that expensive T-case remedy failed again. That, and the continuing squeak from the rear driveline means another root-cause experiment for the guys to figure out. Hopefully the fix sticks this time.
clmrt
So the code 33 corrected itself and all is normal. No idea what happened. I had it inspected for the other issues and here's what came back -
Shocks leaking, rear - may skip and go OME myself
Control arm bushings shot, rear - cause of squeak. Since the squeak is associated with wheel rotation and changes loudness when braking, I wonder if I have a bent axle.
HVAC blower motor, front
Coolant leak, rear heater
Brake caliper leaking, rear
Waiting on warranty inspector to...inspect.
clmrt
No. My wife wanted it, I wanted it, and there were 2 other couples waiting for us to decide. We should have walked but we bit. I did get them to flush the trans, I had a plan for maintenance, and we did buy the warranty to cover our asses. The dealership has been fantastic dealing with this. They go to bat for us every time, and have covered some expenses on our behalf.
At this rate the only original item left will be the lug nuts.
PirateMcGee
Lol, well at least you have the warranty. Still a pain but hopefully it will payoff with a good vehicle in the end.
clmrt
Finally got me. Rear heater hose, failed due to rust, not covered, $720.
Instructed dealer to cap the system and I'll deal with it in the spring. $67 part, looks like.
clmrt
All prices installed
Rear Shocks
4162A023 431.98/PAIR
RIGHT REAR Caliper / bleed
MR510541 587.31 INCL BLEED
HVAC fan, front
MR398725 419.97
Cap rear heater line 122.95
Drive belt tensioner
1345A078 233.06
$1795.27
8 days
Cost to me was $275 including the rental...winning
clmrt
12/12/2014
TRANS MOUNTS
MR448194
NO CHARGE
TRANS FLUSH
MZ320200 X 12 QT
NO CHARGE
KEY / FOB
MR587977 XMITTER 173.78
MR587315 KEY 61.92
LABOR 89.99
325.69
1/22/15
TIMING BELT JOB
MD358549 BELT, VALVE TIMING 150.68
MD362861 ADJUSTER, TIMING BELT 61.40
1345A078 TENSIONER, ALTERNATOR 156.36
MD979171 WATER PUMP KIT 180.16
1305A191 THERMOSTAT KIT 32.39
1100A141 CRANKSHAFT BOLT 16.57
MN155725 ALT BELT 76.06
MZ311986 COOLANT 24.15
LABOR 910.00
1607.77
TRANSFER CASE JOB
MR580151 SWITCH 49.14
MR580152 " "
MR580153 " "
MR580154 " 50.94
MR580155 " 49.14
MR430381 VALVE FREEWHEEL CLUTCH 118.40
LABOR 988.00
1353.90
TOTAL 3070.79
7/24/2015
CEL P0134
O2 SENSOR B1S1
MN158670 SENSOR ENG CTRL 203.13
LABOR 208.00
TOTAL 411.13
VALVE COVER GASKET
MD303148 X 2 GASKET ROCKER CVR 47.26
MD198128 X 6 CYL HEAD SEAL 54.78
LABOR 455.00
TOTAL 557.04
SPARK PLUG REPL
MN153270 CABLE SET 147.97
MR984943 X 6 SPARK PLUG 127.68
702472 X 3 COIL WIRE 66.00
LABOR 39.00
TOTAL 380.65
$1395.88
10/5/2015
HUB JOB
MR418068 HUB ASSY RR 227.38
LABOR 325
552.38
1/19/2016
HVAC BLOWER
MR398725 FAN MOTOR KIT 275.97
LABOR 144
419.97
REAR SHOCKS
4162A023 X 2 230.38
LABOR 201.60
431.98
BRAKE CALIPER DS R
MR510541 CALIPER KIT 336.76
MZ311987 DOT FLUID 5.75
LABOR 244.80
587.31
DRIVE BELT TENSIONER
1345A078 TENSIONER ALT 161.06
LABOR 72.00
233.06
COOLANT LINE, REAR
CAP AND ISOLATE
LABOR AND COOLANT
122.95
TOTAL 1795.27
So Far - $7140.01
Damn.
crostopher
