I want to know if a Toyota pickup(mine is a 93, single cab, 5 speed, 4cyl) 4wd suspension will fit on a 2wd truck. The truck has a body lift already and I want some more lift, and this would be a cheap way to do it, with oem parts, assuming they fit. They rear springs sag under load anyway so I will need new oem leafs or some upgraded heavy duty leafs either way.
What would you guys do? I already have 31in all terrains on it, so I dont need to fit bigger tires, I just want some more clearance.
-Thanks in advance, and no, I cant get a 4wd, I'm in college, and money is tight and I would much rather spend it on some expeditions rather then a new truck and not being able to go anywhere.
