3/4 ton with pop-up as daily driver: Older model diesel or newer model gas?
Overdrive
The suspensions have been completely re-designed in the last couple of years. I believe 2007 would be a 9K GVWR on leaf springs, whereas a new 2500 has a 10K GVWR and has coils at all 4 corners. I'd love to know how a new one handles when loaded up.
brian90744
American Trekker
Changing registration to RV
I also changed mine to RV, thru AAA and saved $190 per yr, and if I need to get a large item I just hook up my trailer. It does seem ridiculess in Calif when most pick-ups are for personal driving not business. If you go to DMV for this change they make you jump thru loops.
QUOTE=ExpoMike;1730831]I did it all at AAA and it was easy. Go in with your camper and say you are looking to register as an RV. They will have you fill out a statement of facts, go out and do a quick inspection, to make sure it quailifies with the required equipment and bam, done. I did mine when I was up for renewal. If you do it midway through a current tags, you won't get any refund. Knocked $220 off my yearly fee. Downside is, the camper can never be off, though I have heard rumors that you can but you cannot haul ANYTHING in the bed other than your camper.[/QUOTE]
arlon
I have a Dodge/Cummins 2500 2wd that I wouldn't give up for anything. It's an 03 so does NOT have cat or DPF, they still got good mileage.. I just drove a 1000 mile trip and averaged 26mpg (hand calc). I have a small camper top that stays on 100% of the time but I do not use it for camping. I have the AWD Astro I prefer for that. The truck does have 180k miles on it and has had no maintenance issues of any sort other than a water pump at 60k miles which is a 15 minute fix on an early Cummins.
If I were forced into something NEW, it would be gas unless I planned to tow very heavy trailers. No doubt about that. If forced out of this truck, I'd just start looking for another 03 even though the prices on them are going up instead of down.
