35mm help
mmscheeler
So, I am trying to get a bit more into photography. I just got a KS Super 2 SR 2000. I need to replace the flash for it. Hoping someone here can point me in the right direction.
Matt
The Sears 8025 Flash was the dedicated unit for your camera I checked ebay and didn´t find one for sale. I´ll try a couple other places and will get back to you if I find one or another flash that will work. Might help to search for someone that has a camera and flash for sale.
Honestly the amount of hassle it will be to find a flash unit for your camera that is both a: available and b: still works, might be the deal-breaker.
You can find a TON of good, used 35mm cameras on Craigslist if you just do a little digging.
Anything that has sharp, square edges and a lot of clicky dials and knobs will be perfect.
The camera I recommend to my photo 1 students that are just learning the darkroom? The tried and true, battle-tested Pentax K1000. You should be able to pick one up for between 50-100 bucks.
Good luck!
OchoSolo
