3rd Gen 4runner Shock Advise
Goin
I have been running tokico trekmmaster shocks for the last 4-5 years (60K miles) and I think the front shocks have finally worn out. I was never overly impressed with the ride I got. I am thinking that the springs are probably ok, but the ride has gotten even worse on and offroad as well as a noise is noticable when the suspension moves. I am running the OME 881 with the small toytec top plate spacer in front and OME 890s in back.
What would you suggest I replace to make sure I get the best bang for my buck? Money is definatly a consideration or else I would go for the full icon setup. Any feedback available for the following options?
Replace front shocks: OME fronts ($260), Bilstein adjustable ($200), sonoran steel special valved bilsteins (not sure if available alone), tokico ($125)
Any reviews on the toytec coilovers? They are more $ than I really want to spend but could maybe spend if they are worth it ($750ish). I would probably not do the rear shocks for a while if I spend this much.
Thanks
Some pics
FLYFISHEXPERT
LivingOverland.com
I have been very happy with the OME Nitrocharger struts. I am running 882s with them for over a year now. I have found this to be a good combination with the LX450 coils and OEM shocks I have in the rear.
I chose the OME Nitrocharger for simplicity, I heard bad things about having to rebuild coilovers.
CYi5
OME is your simplest bet. I love my DR's, but plan on ~$300 rebuild every couple years for coilovers.
98roamer
I too am running the tokico trekmasters with 50k on them and I am surprised how bad they've become. I running OME 880 in the front and OME 906 in the rear of the 4runner. I've been reading as much as possible about what shocks/struts to go with for the best ride. I've read about some of the OME failures, but still a lot more good than bad. Subscribing...:coffee:
Goin
Enzo - back at you.
98roamer - interesting that you are noticing the same decline in the tokico's. Sonoran steel used to put them out with all their 7.0 lifts and I havnt heard about them wearing before.
Cyi5 and Flyfish - thanks for your insight. I will probably go with the OME.
Is the thought that the "OME front shocks contribute to cv failure" still out there?
Still interested in any other reviews out there.
tacollie
Glamper
I say OME. The only time I have issues with cv failure was running 882 coils and no diff. drop and no added weight in the front.
FLYFISHEXPERT
LivingOverland.com
I have had failures on both inner boots with 882's with diff. drop with no added weight. I attribute the failures to the age of the boots. They both failed, nearly the same time, at the end of this past winter, ~9 months after the installation.
Goin
Thanks for the responses. Got the OME's on order and will report back once I get them installed.
Goin
I installed the OME shocks on Sunday and have really been enjoying the improved ride. I took out the small top plate spacers I was running before and I still seem to have a fairly even lift. I think the OME shocks are a bit longer than the tokicos were.
Goin
Definately an improvement over the worn tokicos, however it's not like I'm riding on a magical cloud where bumps don't exist. I think my front shocks (particularly the passenger side) were much worse than the rear. I probably could have gotten away with just replacing the front shocks with new Tokicos and saved a lot of money for only a slightly worse ride. Hopefully the OME shocks will shine in durability and long term performance.
