3rd Gen Montero Transmission Service Advice
tadeon
I have a 2006 Montero Limited with 175,000 miles, but I’m not sure when the transmission was last serviced. I’m considering a drain and refill with Mitsubishi SPIII ATF, but I’ve heard mixed advice—some say there’s a risk of transmission failure after a fluid change with high mileage. Currently, the fluid still looks pinkish-red and doesn’t smell burnt, and I haven’t noticed any shifting issues or shuddering. I’ve watched videos where some people advise against changing it, while others say it’s fine. I want to keep up with maintenance but feel hesitant about this one. Any thoughts, suggestions, or personal experiences, good or bad?
alanymarce
I can't imagine any reason why it would be a bad idea to replace experienced ATF with new ATF (provided it's the right spec of course). I'm interested in seeing any reasons why it would not be a good idea.
Inyo_man
Don't piss down my back and tell me it's raining.
Complete a full fluid exchange with SP3. The procedure is relatively simple. Drain and refill the pan.
Remove the ATF line that feeds the cooler. Cycle the ignition (briefly) so some fluid is pumped out of the line. Replace through the dipstick. Continue brief cycling of ignition until fresh fluid is being pumped out. You'll need about 12 quarts of fluid to do a complete flush. Remember to check the level with the engine at temp., after cycling it through all the gears, then check while running in N.
These transmissions are bullet-proof, if taken care of properly.
I used this mob linked below as a supplier:
Cheers
tadeon
I just completed a drain and fill, draining about 6 quarts from the pan and refilling with SP3 ATF. The transmission shifts smoothly with no issues. I’m planning to do another drain and fill in 10-15k miles.
Michael Brown
You followed me, so now we're both lost
I don't know of any downside to not doing a fluid replacement on these vehicles provided you use the correct fluid and follow the procedure to set the level correctly.
If the fluid was still red in color, it was probably fine. The fluid should be good for 50k miles or much more depending on driving. If you experience shuddering or shift issues, that is likely the sign to change it.
IvaBru
