4/16/25 update Freightliner M2 Mega Cab based expedition camper $99000 in Arizona
Kevox
2008/2022 4X4 Freightliner based expedition camper $129K $114K $99K​
After 2 knee replacement surgeries, my wife finds this too difficult to travel in. We bought a small Class C instead.
The truck:
Truck video PRIOR to build...
2008 Freightliner mega cab 4X4
It has a DPF but no DEF system
Allison 3500 Automatic Transmission
Interaxle lock, and diff lock on rear, not sure about front.
Factory 4x4
Air Brakes
Cruise control
Air Ride suspension and air ride Cab
240 inch wheel base
Governor Speed Hydra mechanical or PSG (2200-2500 RPM)
Horsepower 240 - 400 hp @ 2500 rpm 179 -298 kW
Torque 670 - 1,075 lb-ft
Like New - Heavy Duty Tires on Aluminum Alcoa 22.5 Wheels
Truck currently has 4 bucket seats plus the sleeper.
Meritor Front and rear Diff’s ( Link: https://www.meritor.com/products/axles/ )
- Meritor Transfer case
- Air Brakes
- Free Wheeling Hubs
- Super Single rear
- Shift on “Fly” under 10 mph-
- New Wiper blades
- Quad Bucket Seating
- LED Brake lights
- 46” inch Sleeper
- Air conditioning
- Kenwood Stereo
- Backup Camera
- Alarm
- Heated Mirrors
- Electric Locks
- Electric Windows
- New Carpet
-2 new truck batteries
- Sleeper
- Undercoating
- LED LIGHTS exterior
- Aluminum wheels polished
- Trailer Brake
- New Custom Exhaust
- 4x4
- Clear clean Title
- GVWR 33000 LBS or 14968 kg
• Front Axle GAWR 5443 kg or 12000 lbs
• Rear Axle GAWR 9525 kg or 21000 lbs
• Tires 11R22.5 (H)
• Rims 22.5#8.25
Commonly used 8.3L isc Cummins engine for easy parts/service.
Alaska registration as a heavy straight vehicle.
The camper sleeps 4. It has an extra long queen sized bed in the rear. It has the sleeper cab for 1 adult and the dinette easily converts to another single bed for a child or small adult.
It has Arctic tern windows, door and cargo door.
It has 5 inches of insulation as the box is built from a Morgan Reefer box.
It has a heat pump to keep it cool or warm as needed
2800 watts of solar ( 28 100 watt panels).
48V battery bank consisting of 32 lithium ferrous oxide batteries
Full size inverter fridge
Portable induction cooktop-2 burner
Led lights throughout the habitat
120V Electric water heater (6 gallon)
Outside receptacle
Outside light
Carefree of Colorado electric awning
new spare tire and rim.
Shower enclosure
Natures Head toilet
Cabinets made from the finest plywood in the world-Okume with poplar and pine frames.
120V outlets, 12V outlets, Usb outlets
The box is welded to 3 inch tubular steel which is welded to the frame-(no articulating subframe).
80 gallon diesel tank
Vinyl plank flooring over Okume plywood over original aluminum floor
Kevox
I bought it for 85K with the reefer box empty. I put a lot of time and money into the build. Current mileage is about 81,000.
Overland By Kyle
Clean ring, thanks for sharing it with us. How was your experience building out the reefer box? I’m looking at placing a reefer box on the back of an M 1089. Did you have to do any sub frame work for getting the box off road? I’m sure break over angle would be a concern with Off Roading, do you consider this an expedition rig or more of a getting out of the snow type of 4 x 4?
Kevox
Thanks. The five inch thick walls were tricky to cut cleanly and straight. The box has a thermal barrier at every stud which is great. My last rig was a job which was much more capable off road but I expect this to be excellent in snow, packed sand etc. Great for the western US and Baja.
Kevox
I started wit an RV which couldn't even handle washboard roads without damage to cabinets and a cracked window. Then I had a MOG which could go anywhere but wouldn't fit 3 adults and 2 dogs...This rig can handle very bad roads, BLM and forest service roads etc. I would drive it to 99% of the places I've visited in Baja. In the Mog, I would park on the beach. In the Freightliner I would evaluate it more closely first.
Kevox
2008/2022 4X4 Freightliner based expedition camper $129K​
I just made a 2 year commitment to a job in Ketchikan, Alaska and can't take my expedition camper with me. The build is 95% completed at this time. The truck is currently located in Furnace Creek in Death Valley, California.
The truck:
Factory 4x4
Air Brakes
Cruise control
240 inch wheel base
- Air Brakes
- Super Single rear
- New Wiper blades
- LED Brake lights
- 46” inch Sleeper
- Air conditioning
- Kenwood Stereo
- Backup Camera
- Alarm
- Heated Mirrors
- Electric Locks
- Electric Windows
- New Carpet
- Sleeper
- Undercoating
- Trailer Brake
- 4x4
- Clear clean Title
• Tires 11R22.5 (H)
• Rims 22.5#8.25
- Tires 90%
Currently owned through a Montana LLC and registered as a commercial vehicle but I have started the paperwork to convert it to a motorhome registration.
It has a heat pump to keeo it cool or warm as needed
Outside receptacle
Outside light
new spare tire and rim. (have hanger but not yet mounte).
Shower enclosure
Natures Head toilet (fan not yet installed)
The fit and finish of the cabinets is not professional quality but looks decent and is very strong...will outlast any motorhome factory cabinets.
Remaining tasks​
Install greywater tank under truck
Install storage boxes if wanted under truck
Install Military grade bracket for spare tire under truck
Shower is plumbed to below the habitat and would need to be connected to the greywater tank when installed.
Plumb sink drain to greywater tank
Install trim around door and bedroom area (back wall)
Add some cosmetic siding to the exterior back wall
Install trim around shower supply lines if desired
Install 12V line to fan for Natures head toilet.
Install latching hardware on cabinets
Paint trim and some shelving
Buy or make cushions for dinette area (have fabric and may make them prior to sale)
Buy mattress
Install box extension and finish temped in heat pump wiring connection
Other stuff I'm forgetting :)
Price drop by $10,000 to $119k plus interior video
rrexerr
Still available? Do you need a Commercial Drivers License to operate this since GVWR is 33,333 lbs.?
RobbK
The truck:
Factory 4x4
Air Brakes
Cruise control
240 inch wheel base
- Air Brakes
- Super Single rear
- New Wiper blades
- LED Brake lights
- 46” inch Sleeper
- Air conditioning
- Kenwood Stereo
- Backup Camera
- Alarm
- Heated Mirrors
- Electric Locks
- Electric Windows
- New Carpet
- Sleeper
- Undercoating
- Trailer Brake
- 4x4
- Clear clean Title
• Tires 11R22.5 (H)
• Rims 22.5#8.25
- Tires 90%
Outside receptacle
Outside light
Shower enclosure
Remaining tasks​
Buy mattress
Do you have dimensions on the REFER portion as well as inside head height?
Also is there a site that has additional photos of the bed area, battery storage etc?
Thanks
Kevox
Thanks
Finished floor to ceiling is 6 ft 6 inches.
Inside width is 7 ft 3 inches.
Inside length is 14 ft.
Bed platform is 5 ft x 7 ft 3 inches
Kevox
Kc_trailhawk
