nckwltn
Is it possible to swap the 4.636 gears from an LS with 4.636 gears into my 99 with the 4.2xx gears?
I don't want to lose my locking ability, so can I swap over all of the necessary locking bits?
A local parts pick place has an LS with the engine and drive train yanked... should make it much easer to get the front out as I have access from top and bottom.
Although there is an SR at another parts place with 4.636 gears with a locker that I could pull the rear from.
I want to bump up to 33" tires, and figure that if I can swap the gears out, I might as well.
**UPDATE I've you stumbled upon this thread because you're thinking of doing the same thing, DON'T! Read to the end to learn more, but the short version is that the LS with the 4.636 gears have a 7.25" ring gear, while the SR that bolts more readily to the gen 2.5 uses an 8" ring gear. You want the 8" ring gear not the 7.25". The 97 LS may have come with the 8", but research it. A quick way to tell is to measure the outside of the diff housing. The outside top to bottom measurement of the 7.25" ring gear diff housing is only about 8"... so clearly an 8" gear isn't going to fit inside.
