4 door Bronco Driver Side Power Tank Mount $100
watrboy
I am selling a 6th Gen Bronco Driver side Power Tank Mount with Fire extinguisher mount. I am in Laurel, MT and can ship this part in the lower 48 for $30.00, or you can pickup.
From the Power Tank Description:
The 4 Door Bronco Plate bolts on to the roll bar of your 4 door Bronco using simple hand tools in less than 20 minutes with no wiring to connect or air hoses to plumb. The Bronco Plate has been designed to mount 5 lb, 10 lb, and 15 lb Power Tanks as well as 5 lb and 11 lb steel propane tanks and 6 lb and 10 lb aluminum propane tanks and their brackets. In addition, there is a quick-release fire extinguisher bracket already installed.
The best part is that this bracket is STOUT. When properly mounted, you can rock the whole vehicle just by shaking your Power Tank. This gives you peace of mind when you're bombing across the open desert. The strength comes from a hardened steel frame and billet roll bar clamps. The roll bar clamps can be used on their own as a base to mount other accessories.
This Bronco Plate does not include a Power Tank or propane tank bracket. To mount a Power Tank, you can use the Super Bracket that is standard in most 5 lb, 10 lb, and 15 lb Power Tank packages or purchase one separately. A Quick-Release Fire Extinguisher Bracket is included.
2eleven
