4wd lifted overlanding bus - Sold
Merakivanman
When you want the comforts of a full size RV but still want to be able to get off-road for extended periods of time this is the ideal way to travel. This has over 12 inches of ground clearance and 4wd locking hubs with off-road all terrain tires you can just about go anywhere you want. Just updated* one way privacy vinyl wrap on windows
It has A/C, 2 furnaces (one propane and one from the coolant lines of the engine. I’ve run the heater for weeks straight and barely makes a dent in the propane.
2010 Fully customized Class B motorhome conversion 25 foot length 6.8 liter v10. 125k miles - 70,000 or best offer.
50 gallon fuel tank. Range is longer than it takes for nature to catch up on the road but will get around 10mpg on non-mountain pass highways.
4wd Hi/Lo Dana lockers with a 6 inch lift kit and 4 inch bigger tires than stock. 10 inches of additional ground clearance. 1200 miles on the 4wd conversion
Plumbing:
Recirculating Indoor shower with 5 stage sediment/carbon and UV filtration. 30 minute hot showers and completely filters the water without using up additional fresh water. Possibly the best part about travelling on the road and off-grid for weeks at a time.
Outdoor shower with hot/cold from freshwater tank.
Isotemp stainless Steel electric 4.5 gallon water heater. (High-end Marine grade) for sink and outdoor shower
On demand 2.4 gallon ceramic coated electric water heater for shower.
40 gallon onboard freshwater tank w/automatic freeze protection mats and additional 10 gallons for shower.
105 liter DC Fridge/Freezer
Queen Sized bed
Cassette toilet
60lb undermount Propane tank. Lasts up to a month of continuous use in cold weather.
16k BTU electronic ignition suburban propane powered RV furnace with wall mounted thermostat. Dual zones for front and rear of vehicle (Sips fuel and is super quiet.)
Auxillary furnace from engine heat
Rear Mounted A/C - pumps ice cold air
Electronic Ignition 2 burner propane Stovetop
Full- Sized Stainless steel Kitchen Sink
Birch butcherblock countertop
Electrical: All brand new components
600 Watts of Solar
60AMP Charge Controller
300 watt led off-road flood light bar
Maxair - Low profile Remote high volume Roof Fan. Automatic rain sensing and allows fan to be run with it lowered at the same time
2000 Watt inverter with remote switch
600AH AGM battery bank - 2 months old.
3 zones of touch sensitive led lights for upper and lower lights
Led touch sensitive reading lights on bed
Dual USB plug-in
Low profile 120v pop up 3 socket electrical
4x4 System - Leafsprung/dynatrac/spicer Dana 60 Front Axle, NV 271 High/low Transfer Case, Detroit Locker Dana 70U with 35 Spline Axle Shaft upgrade rear end. 1200 miles on 4wd system. 33 inch ATP all terrains
Storage under bed
70k obo but reach out if you have additional questions or want additional pictures.
Willing to deliver. Bus is located in MN.
Merakivanman
How much stand up height is this? Maybe I skipped over it, but can I stand up in this at 6'5"?
Out of luck at your height without a higher center section. East enough to do but currently sits a couple inches shorter than you. I’m 6’2” and it works but I’d prefer a skylight in the future.
Supreet.dhaliwal
