4x4 Off-Grid 4 season Ram 5500 Expedition Vehicle - $295,000
jjames111
Skip the wait to have one built. By the time it was finished I already moved on to other projects.
Selling at a big loss. But your gain.
Full 4 season go anywhere expedition vehicle ready to go!
4×4 Ram 5500 Crew Cab Off-grid overland Camper.
TRU-Earth self leveling system installed on liquid springs. All maintenance completed at 8000 miles. Oil change, tire rotation, liquid springs, and ac charge.
Current Milage 9000 miles. Build, suspension and tires were done at 3500 miles.
Secured with Keysavvy.
Free and clear title. Nearly Brand new – but fully tested.
Professionally built – (not diy)
Fully stocked, Everything included – TV, Camp chairs, pots pans, glasses bowls, power tools, – down to the coffee frother. (included as free, not factored into price)
Open to delivering if purchased.
About the crew cab Ram truck:
14,820 lbs Dry weight (over 4,000 lbs under max weight!)
Total height – 11′ 6″
Length of habitat: 13′
Total length: 26′ with spare tire.
  1. Ram 5500 Crew Cab tradesman with 6.7L Cummins diesel engine with upgrades like nav screen, tow package, snow prep package.
– Liquid spring suspension and DBL super single tire conversion. Rear full size spare tire with carrier that pivots to assist with removal.
– Approx. 11′ long HEAVY DUTY steel
subframe with incorporated “rail on rail” captive spring mounting system and fixed points in the front. This system ensures there are no pressure points or abnormal stress applied to the habitat yet allows maximum flex to utilize vehicle off road capabilities to the full potential.
  1. Custom Army tan paint job in rugged Bed liner paint. Black Line-X paint for front grill storage lockers, rockers, & fenders
– Full size custom front bumper brush guard (to protect the entire front and not just the bottom) Winch hookup cut out (no winch), 20” rigid light bar and 4 ridged fog spot lights (all individually wired in pairs for lots of light, tons of light and… blind everything light)
– Max tow package – 4.89 axel group. Skid plate shield (snow prep package)
– Radio Upgrade
U-CONNECT 5 NAV With 12.0″ DISPLAY
Google Android Auto, Off-Road Information Pages, Trailer Tow Pages, Disassociated Touchscreen Display, HD Radio, Connectivity – US/Canada, 12.0″ Touchscreen Display, GPS Navigation, 4G LTE Wi-Fi Hot Spot, SiriusXM w/360L, All Radio Equipped Vehicles, Connected Travel & Traffic Services, All R1 High Radios, Alexa Built-In & Apple CarPlay.
Side steps – rugged black painted side steps for access into the cab.
– Custom polyurethane saddle brown seat covers, Front seat can convert to a 3 person bench seat. Weather tech floor mats and weather tech window shades for all 5 windows + weather tech dog door protectors. (We do not have a dog but it was planned incase we got one) Small plug in inverter for the front seat incase passenger is working and needs to charge a laptop or other accessories.
– Wireless, solar charging back up camera with 7 inch screen.
– Full back seat platform with access below for storage and 5” memory foam mattress for small guests or pets (big dog or dogs). Could add captain chars for the kids.
Locking door for direct access into the camper.
About the Off-Grid Overland habitat:
Windows and Doors
6 Arctic Tern awning style windows with build in screens and black out curtain shades. sizes – 3 X-large 21.6″ high – 57″ wide! 1 medium, 2 bunk.
1 door with key lock, window, window shade and built in full door screen.
1 24” door to access crew cab through the habitat.
6 Waterproof locking doors for under lockers and exterior/interior lockers. 4 for storage, 1 interior locker for water tank, outdoor shower and access to hot water temp adjustment. 1 under exterior locker for gray tank and access to drainage.
1 Ceiling fan with remote.
1 opening (with remote) sky light with light, screen and sun shade.
Habitat construction
Lightweight, High impact, Thermal transfer free – UV Stable, FRP Skins.
Laminated high density EPS thick foam walls and ceiling R15 and R12 high density insulated floors with honeycomb core (high strength with no wood) Water and freeze proof. This rig stays warm!
– Aluminum storage boxes on either side of wheels with stairs incorporated inside of the box underneath the door.
Electrical
All your electrical – Solar, battery %, input, output, water tank %, Gray tank %, water and gray water temperatures can be seen on your monitor inside the habitat.
If traveling away from the Camper – You can also access it remotely online to keep an eye on your battery % and water temps as long as the starlink has access to the sky.
600ah EG4 24v LiFePO4 batteries, 19,200Wh (equivalent to 1600 ah @12v)Victron Energy MultiPlus-II 2X 120V,
3000VA 24-Volt Pure Sine Wave Inverter and 70 amp Battery Charger Victron Energy Phoenix 800VA 24-Volt
120V AC Pure Sine Wave Inverter – Dedicated to Small appliances & Starlink
1200w/1500w (Hyperion 400W Bifacial Solar Panel (Black) | Up to 500W with Bifacial Gain)
Victron Smartsolar MPPT 150/60-TR Solar Charge Controller – VE.Can – UL Approved
Victron CerboGX with GX touch 50 monitor Victron Lynx Shunt, x1 Lynx power in, x2 Lynx distributor
100 amp Victron Buck Boost Charging via alternator (x2 50a) Victron Energy Orion IP67 DC-DC Converter 24VDC to 12V 100AMP
“Misc Blue sea, Victron, Anchor and various other components Marine grade wiring & components used throughout
120V AC outlets throughout, including one in gear garage & overhead storage cabinet 12V DC USB ports with 2 standard DCs.
What all your levels on the monitor – Electrical incoming and outgoing, Current wattages, water levels, water temps, – as well as you have the ability to log in and view the levels remotely as the truck auto turns on heating to prevent water tanks from freezing.
Lighting Exterior and Interior
Interior: Dimmable LED ceiling, Dimmable LED task lighting under cabinets, LED reading lights over dinette areas, Over Bunk – 4 lights + 2 remote controlled led color changing rechargeable lights + skylight light with remote. Exterior: LED marker DOT lights surrounding the vehicle; two LED patio light near main door and two on driver side – dimmable and controlled by switch inside + switch for awning light.
Bathroom & Shower
30” shower and composting toilet, Full height standing shower that drains to the gray tank. 22 Gallon grey water tank servicing sink and shower.
Plumbing:
66 gallon High capacity, BPA free fresh water holding tank mounted inside for freeze protection. Grey Water Tank Size- 22 gal.
Additional Plumbing Features include
  1. Premium water pump with accumulator and silencing kit.
  2. Cold/hot water port in gear garage (outdoor shower)
– Endless hot water system via hydronic heat and electric element (can control water temp – if you want, it can get burning hot!)
Heating & Cooling/Kitchen & Appliances:
Air Conditioner – UndermountAC® 24v 16k with integrated HVAC ducting
Espar hydronic heater
Integrated Infrared Electric Heated Floor System (Miheat)
CONTOURE microwave air fryer combo, Furrion 2-Burner 21″ RV Induction Cooktop (Black) isotherm slim 140 Refrigerator with freezer top storage
Matte Black van life tech Folding Faucet with extra long sprayer & Stainless Steel Nanotech Galley Sink
Black and decker fast 1200w toaster and Nutri-blend blender (both fit in their box conveniently in one overhead cabinet with room to spare.
Heating, AC, Fan and temperatures can be controlled through your hard wired screen inside the habitat. Switching from AC to Heat is set up manually to avoid issues with heat values (but a heat value can be added) It is a simple turn of the nob inside the storage compartment.
Flooring and Cabinets / Furniture and Countertops
High quality Durasein white/light gray Carrera marble like countertops
Premium synthetic plank flooring
Dining Table with large U shaped convertible couch to guest bed and 5” foam Cushions.
Cabinets: ZERO wood construction using primarily PlyBoo.
pull-out storage drawers with soft close hardware
High Quality Latches throughout in black.
Wardrobe closet – hanging
Premium Queen size Residential Memory Foam Mattress ; Froli under mattress system
Bedside storage, bedside floor cabinets and side wall open storage for easy access.
TV / Movies
24” 1080 Smart TV with indoor and outdoor full motion locking RV mount + additional mount (unmounted) TV can be placed outdoors to watch your favorite movie while camping.
VOPLLS Movie Projector – 360°Adjustable Stand & Auto Focus/Keystone – with WiFi and Bluetooth, 550ANSI Native 1080P. HDMI/USB/Phone/PC (Black)
150 Inch anti-crease washable outdoor projector screen.
Starlink
Starmount mounting system with quick release to take your Starlink home when Camper is not in use, starlink router included, starlink dish included and account can be transferred.
Fully stocked, Ready to Camp – all included. Especially if picking up, and you
want to make a trip out of driving home. Currently located in Jackson Wyoming - great place to start.
Security
Blink wireless motion camera system – 1 interior camera and 2 additional cameras (newest models) key lock for main truck cab with key fob for push to start.
The Camper will be detailed as best as possible before pick up and everything will be washed/cleaned inside.
Only items not included which may be in photos – (our clothes, hats, decor blankets, shoes/boots/slippers)
More photos on Vanlife Trader.
jjames111
Beautiful rig. I love how open it seems to be on the inside with all the windows. Who did the buildout?
Would probably add more pictures here. Good pictures make a rig sell quickly ;-)
Good luck with the sale.
Thank you, It was built by Mesa Overland. Took 13 months from start to finish. EP only allowed me to post 10 photos for some reason. Some
builds go with bigger bathrooms - this one is a little smaller but I do like the living are more open and bright since theres also an outdoor shower.
Thank you!
Jack Mac
Expedition Portal Staff Member
Staff member
Thank you!
Hey
You can add extra photos to the comment section :). Nice rig!
jjames111
Some more photos.
