5-pin bulkhead or panel mount plug source
delmartin
I have a Cobra WX75ST CB with a remote connector box which has a 5-pin mic plug (as seen in the attached image). I want to mount a bulkhead or panel mount plug into a plate on my dash (with a cover if available). So I'm looking for a bulkhead plug to replace the plug in the image.
I've searched the internets for plugs, but am turning up with nothing.
Anyone have any leads? Thanks.
-Martin
gary in ohio
-Martin
Pretty much any radio shop should have it, I think Radios shack even has them.
A quick google search of "5 pin mic connector" turned up
http://www.universal-radio.com/catalog/parts/micconn.html
http://www.k1cra.com/catalog/product.aspx?productID=1852
http://www.mcmelectronics.com/produ...ecommendation&utm_source=prod&utm_term=27-730
http://www.therfc.com/micconn.htm
and many more.
delmartin
Thanks for the reply Gary,
Those sites show male plugs. I found plenty of those. I'm looking for a female 5-pin panel mount plug. These seem to be rare as hens teeth.
I went to my nearby Radio Shack, but the sales kid hadn't a clue what I was talking about. Also went down to the local Ham Radio Outlet. They weren't much help either.
Maybe I will have to fab something up myself.
-Martin
MotoDave
I'ce looked into the same thing, my Waytek wire catalog has 2 potential receptacles that look like they may work, although I haven't tried either. Look up Waytek p/n 38543 or 38597.
gary in ohio
-Martin
From the photo, I assumed you need at mate to what you had in the photo.
If all else fails change the plug on the cable you have now to match the 5 pin female connector you can get.
or if you dont want to change what you have make a jump with the correct connectors on it.
delmartin
Gary:
I think I'm going to have to do as you mentioned. Switch out the plugs. Seems as though there are plenty of male 5-pin panel mount plugs out there. Should have just done this in the first place.
MotoDave:
Good site and nice product. Bookmarked for future reference. I like the dust cap (P/N 38564) especially since most of my trips are in the dusty desert areas.
Well, I found a good thread on this type of install. Exactly what I'm going to do.
http://www.expeditionportal.com/forum/showthread.php?t=41291
-Martin
Palehorse1
-Martin
Martin,
Amatuer Electronic Supply has the part listed in their print catalog that I believe you are looking for listed in their "micorophone audio & DIn connectors" section as a "Vanco CBC-5 5-pin female microphone plug."
Goldenbora
