Ramdough
1999 Stewart & Stevenson M1083A1 W/Winch Overlander - $95,000 OBO.
• 3126 Caterpillar Turbo Diesel Engine @ 330 HP
• No emissions or DEF
• Allison Automatic 7 Speed Transmission
• 6x6 Wheel Drive
• 3.07 “High Speed Gears” Installed – New Meritor Assemblies, not reproductions
• A/C System – New Factory Kit
• Detroit lockers in both rear axles
• Factory Self Recovery 15,000, lb Hydraulic Winch with 280 feet of cable
• A1R Rear Pintle Assembly – Sliding pintle hitch and reinforcement
This MTV has been converted into the ideal overlander setup that’s ready for you. The truck has all the sought after features: Cold A/C, “High Speed Gears”, Axle Lockers, and more. This truck will run at highway speed (65 mph+) and exceeds off road capability while doing it in comfort. The frame was professionally lengthened to accommodate the 19’L x 8’ W camper body which was custom built for this truck. The spare tire carrier was relocated to allow for a “walk through” between the cab and camper – a unique and incredible convenient feature for quick cab access and auxiliary storage space. The cab was fully stripped and rebuilt with Dynamat and insulation to help eliminate noise and insulation for heat/AC. All dash panels and systems have been thoroughly gone though and switches for additional systems are installed and wired for future use. Many more upgrades were performed, feel free to request the full details! Photos and video! The truck currently shows 5061 miles which match the engine ECM. Miles may increase as the vehicle is in use by the current owner. It starts instantly and runs strong. The “high speed gear” swap makes for smoother shifting, better power, and better fuel economy. Cruising at 65 mph is easy and the truck is setup to tow a trailer, follow vehicle, or etc of your choosing. The camper body size was designed to sleep 4 adults comfortably. The onboard Pioneer minisplit heat pump/AC is efficient as it is silent allowing for nighttime operation. A WiFi module is installed into the minisplit unit so that the future owner may install home automation and network integration if they so desire. The roof was designed in mind for solar panel installation of 2000 watts and has room be supplemented with a power source of your choosing – propane, diesel, gas, or more panels. Currently, the truck itself is finished and ready for the living quarters to be finished out by the next owner. It’s a blank canvas to build your vision. Feel free to ask questions. More photos and video available upon request. Fly in and drive the truck home, it’s ready to go! Yes, we have a clean title too. Truck is located near Austin, Texas Price: $95,000, open to reasonable offers. No trades.
• 6x6 Wheel Drive
