chadzeilenga
Hi All,
Trying to find the source of a slow transmission leak in my 89. I pulled the pan last night hoping the pan gasket was the culprit, but pan bolts were all snug. With everything out of the way it's easier to see other sources. I see some weepage near the Manual Shaft on the Drivers Side and was thinking of replacing these seals while I'm there (both sides), but cannot find a replacement anywhere except Partsouq (MD951333 or MR111500). I know these AW371 transmissions were in other vehicles such as Toyota, Volvo etc.
- Anyone here changed these out before?
- Does anyone know if this seal would be different in these other platforms? Pictures I could find all seem to be the same
- Does anyone know if the AW372L is different from the A44DL or the A43DL? I see that these are in the same Aisin-Warner 03-71 family, so I'm thinking the cases would be the same and I could use seals from a 00 Tacoma 2.4L 2WD
