97 LX 450 Locked and Loaded
TexasD-90
I am offering for sale my Lexus LX 450. The only reason for selling is that I am considering another project. My family and I have made several trips in this truck including a 3,000+ mile trip from Texas to Oregon (via: New Mexico, Colorado, Wyoming, Montana, Idaho, California, Utah, Nevada). I would not hesitate to drive this thing anywhere.
1997 LX450
190,000 miles (still driving it)
Suspension:
-OME springs
-850J front
-863 rear
-30mm spring spacers on all springs
-OME shocks
-Land Tank caster plates
-Custom rear lower control arms (.33” longer and sleeved with 1.75” .120 wall)
-extended rear sway bar mounts
-front sway bar not installed, but is included
-front and rear adjustable pan hard rods with slee poly bushings
-New Toyota bushings:
-sway bar mounts
-front radius arms
-rear LCAs
-rear UCAs
-Stainless braided brake lines
-This is a very well sorted set up. Everything works flawlessly.
Armor:
-ARB up front
-custom rear bumper with spare tire swing out
-custom built step/sliders
Exterior Accessories:
-10,000 pound smittybuilt winch with synthetic winch line
-rigid LED work light on rear
-rigid LED dually lights on front (need to be rewired)
-hi lift jack on spare tire
-all clear light covers front and rear except for red marker lights and brakes
-LED marker lights
-I believe 7 cree reverse lights (I need to look back to make sure they are 7)
-bottom of truck sprayed with U-pol raptor liner
Running Gear:
-Factory lockers front and rear
-center diff lock switch
-5.29 nitro ring and pinion gear sets
-nitro chromolly birfs (the new high mileage ones)
-DC front drive shaft
-rear drive shaft re-sleeved and balanced with new OEM U-joints
-EMS stainless exhaust from headers back (new cat and muffler)
Wheels and Tires:
-5- 37x12.50x17 BFG KM2 tires (less than 10,000 miles on them)
-5- Hutchison Rock Monster double bead lock wheels (DOT approved)
Interior:
-all new leather on front two rows including door arm rests, head rests and center console
-front seat heaters
-Fat Mat sound deadening throughout entire truck
-dual battery set up with national luna harness and gauge
-Blue sea fuse panel wired and installed in rear quarter panel
-Third row seats included, but not installed
Preventative maintenance and service:
-front axle completely rebuilt with all OEM parts in spring 2013
-rear axle rebuilt with all OEM parts fall 2013
-new front and rear brake pads fall 2013
-new rear rotors fall 2013
-new brushes in alternator
-Full tune up:
-belts
-plugs
-wires
-distributor cap
-rotor
-all fluids changed in engine and diffs before every trips (this is an extra vehicle and doesn’t see 8-10 thousand miles per year)
-it is the original head gasket, but shows no signs of issue (if it ever did I would replace it)
Hit list:
-CEL light comes on and off from time to time. It is an EGR code. Doesn’t cause any issues.
-I would like to recoat the bed liner due to a few chips in it
-front bumper is bent on the passenger side from a winching accident (see pics)
-the same winching accident broke the wires on the rigid LEDs on the bumper
-antenna mast is broken off. I have a new one, but not installed.
I am sure I am forgetting something, so if you have questions please ask. The truck is located near Graham, TX. The price is $19,500.
There is a build thread on ih8mud.com Just search for TexasD90 in the 80series tech section. It is not complete, but is does detail some areas of the build.
taunger
