'99 4 runner suspension build
NODNARB
We are starting another smallish project in the next week or so, so I figured I'd try to actually document this one. Goal is a decent off road ride keeping room to sleep in, storage, etc.
here's the pile of plasma cut parts to make these arms.
Truck gets dropped off this Saturday, stay tuned!
NODNARB
Got the lower arms welded up, headed to pick up the OME rear coils now.
Rear is getting the coils and King bolt in 2.5" shocks.
NODNARB
Checking clearances/making shock mounting points. Looks like a hair over 14" wheel travel possible, and will be all bolt on.
LR Max
Local Oaf
Nicely Done. Also look at Tundra front axle shafts. Stock, they are longer. That might be a better solution than what you've got going on there.
Otherwise, excellent welding!
shmabs
If I was a betting man, I would bet that those shafts are purely for mockup.
Mike
NODNARB
Mike
What he said! Just to check length, that shaft will go to our axle guy to make a pair of 300m shafts.
As of now, no plans to delete the lower balljoint. Total chaos already makes an adapter, but generally balljoint failures come from over extending them from what I've seen. Bumpstops and limit straps are balljoint's friends.
NODNARB
nice build, lets see the rear.
Hey, I know that screen name!
Rear hasn't been touched yet, going to gusset the uca mounts and set the front down then do the rest while waiting for the axle shafts to come in.
orbot
From DR or tacoworld i did the front recently and looking for ideas on the rear pretty much set on ome 906 and performance fox or bilsteins 5100
NODNARB
Got the new 300m axle shafts connected to the rebuilt/cleaned up cv's. Gotta finish one other truck and then I'm back into this project.
mtnkid85
Those shafts are good looking! What did they cost if you don't mind sharing? Would he be willing to do another set?
Tdavis8695
