99 4runner: First phase nearly complete...
Martinjmpr
Wiffleball Batter
Well, I'm happy to say that the "baselining" of my new-to-me '99 4Runner is nearly complete. I had the T-belt/Water pump replaced at a local independent dealer, and had a few other odds and ends done too (seals and swaybar bushings.) A bit costly but at least now I can breathe easier since, at 118,000 miles I was almost 30,000 miles past due o the T-belt!
The other annoying issue was the dead power antenna. Last night I bit the bullet and pulled off the fender liner to get to the antenna. I ended up breaking several of the plastic "plugs" that the fender liner screws go into, but I'm guessing that if I really need to replace them I can get a bag full of them from my local Toyota dealer for 10 or 20 bucks. Good news for anyone else with a similar problem (dead power antenna that makes a godawful noise when turning the ignition on or off): Once you get the fender liner off, there's a plastic electrical connecter on the inside of the fender just forward of the antenna. Disconnect that and PRESTO: Noise gone (and the antenna still works - yes, I checked!)
Final bit of work was to install the XM receiver. Not a lot of room on the dash but I ended up putting it in the same place it was on my Tacoma, just left of the steering wheel, and above the diff lock switch. It does hide the diff lock switch a bit but that's not a big deal to me, I know where it is and there's a dashboard light that comes on when the diff lock is activated anyway.
Only other remaining detail is to replace the shattered glass of the driver's side mirror, which I hope to do next week.
The luggage rack crossbars and the running boards are off, so once I get the mirror fixed I can start thinking about mods. What I'd like to have eventually would be a 2.5" OME lift, an ARB front bumper (with the possibility of a winch in the future although that's a long ways off) and some low profile rock sliders. Beyond that, the only other mod I'd make is something to convert the inside for sleeping (probably a removal of the lower back seat cushions along with a removable platform of some type.)
Taking a trip to the mountains for some flyfishing this weekend so I'll have a chance to see if the MPG is any different with the crossbars off and the transmission in "power" mode.
evan
Cool. Sounds similar to what I'm about to get myself into when my new to me 98 is delivered to me on Sunday.
What's your plan for the mirror? Is it power? The driver's side mirror casing on mine is broken so I'm looking for a replacement. I'm thinking about trying the full unit sold by AEON Imports on eBay but I'm a little hesitant since I can't find somebody else who has used them.
Where did you install the XM antenna?
Martinjmpr
Wiffleball Batter
For my mirror it's only the glass itself that's broken so I need to pick up a replacement from the Toyota factory (about $60) and then remove the old one. Apparently it's glued on, so I have to heat it up with the heat gun and then peel it off.
The XM antenna is a magnetic and it's on the roof right behind the drive'rs door now. Eventually I'll go to a more permanent setup, possibly a new head unit because I hate the Sony head unit that was in it when I bought it (I'm going back and forth between reinstalling a factory AM/FM/Cassette/CD unit or getting a new head unit that can play MP3s.)
CYi5
Glad to hear everything is working out. Might want to start a build thread to keep everything contained, you've got like 8 threads going right now :Wow1:.
dhuss
