'99 OBS Tahoe - lift choice
Saiyan66
The 6" lift was alright, but most of the newer style lifts use a lift knuckle instead of dropping the upper arms. This usually increases your track width in the front a bunch and looks really weird. A lot of IFS lifts have alignment issues if you use them at all off road, although my RCD was ok in this respect. I just wished that I had saved my money a little more and either bought a different truck or done a SAS with it. I think for reliability the majority of opinions on here are very correct. Leave it as stock as possible or go straight axle. You could always just spend that money at a local body shop to have them trim the fenders and get everything looking factory again if all you want to run is 33's.
Spargman
Agreed - I think the knuckle lifts look a little weird. Not bad if it's a mud truck, but i'd like this thing to still look good everywhere I take it.
I heard the RCX kept the alignment pretty solid for guys that wheel pretty hard...but I've definitely heard of a few others that were a disaster.
Stock height on 33's would require a little too much trimming for what I'd like to do... but I'm also thinking of possibly a 2" body lift and 1" tbar crank. I don't like how body lifts look, but 2" isn't too bad. I also have almost brand new Bilstein HD's so I would save quite a bit if i did a simple body lift and 1" tcrank.
Personally I don't mind spending the $$...I want to do this the right way, but not SAS.
On that 6" lift, how many 4x4 miles did you put on it?
Saiyan66
Not too many off road miles, it was mostly a street cruiser. It did fairly decent off road though with 35" BFG muds, Bilsteins and no sway bar. Hated the add-a-leaf in the back though. Should have ponied up the dough for new rear leaves.
Ryan1975
Did you happen to put together parts list for brake upgrade yet? Ha!
I may end up following your exact lead on a lot of things you do.
timsbroncs
"Stock height on 33's would require a little too much trimming for what I'd like to do... but I'm also thinking of possibly a 2" body lift and 1" tbar crank. I don't like how body lifts look, but 2" isn't too bad. I also have almost brand new Bilstein HD's so I would save quite a bit if i did a simple body lift and 1" tcrank."
I am running 285/75/16 = 33.1" with stock suspension on a 1998 k1500 with no rubbing but it requires wheels with better backspacing and no trimming required.
Tim
