WhereTheHellIsJames?
I have a '95 Tacoma with 250+k on the (V6) ticker, and for the last year or so there has been a couple of issues with the truck that have left me less than satisfied- not with the truck, but rather, the performance etc.
Firstly, The engine stuff:
I've an intermittent misfire on the #3 cylinder. It has happened here and there (mostly at certain altitudes on certain grades in certain temperatures and humidities), and comes and goes infrequently- sometimes it does it, then it'll go 6 months without doing it again.
Then there is the vibration that I'm getting from the exhaust manifold shroud on the rear of the engine- the one that you really can't get to unless you start moving the entire engine around.
Also is the decline in power over the last several years- the engine just seems like it has lost some of its pep.
Lastly, it's due for a timing belt again.
Then the other stuff:
I need suspension and brakes. Rear springs are sitting pretty flat these days, and the front feels a bit washy.
The transmission shifts well- I did overheat it once (although as soon as the light came on I pulled over and let it cool down), then changed the fluid within a week.
The transfer case has a little dampness around the seal, but not enough to call it a leak.
So here's where I need your advice:
I'm thinking it is either time for some major work on the rig, or it's time to unload it onto someone else. Below is my pro's / con's list... what would you do?
Pro's:
* I know the entire history of the truck, what it needs, and cosmetically it's in great condition in and out.
* I found a used engine with 86k on it, and it's TRD SUPERCHARGED ($2100, and compression is 188-189 psi in all 6)!
* I have a set of 63" Chevy springs in my garage, and they're in great shape.
* I think that with an investment of say, $4k or so, and a few days, I could drive it for another 200k reliably.
* I hate buying used rigs, and I can't justify the price of a brand new truck.
Con's:
* I'm a bit tired of the truck... but maybe it's just because it has some issues. If it ran & drove like new again, I'd probably be really stoked on it.
* I might sink a bunch of money into the truck, only to have some other big ticket item go wrong with it (such as the transmission).
* I like the look of the last generation of Tacoma's (through 2004), and have wanted a double cab for quite some time.
* I think engine swaps are a pita.
* I'd bet that if someone hit the truck the day after I fixed it all up, the insurance company would total it (such high mileage) and would pay out about $2500- less than what I had just dumped into it.
Opinions please:
Keep it and fix it up for an estimated $4k or sell it for an estimated $3-4k, and go look for another rig?
Pro's:
Con's:
Opinions please:
