Advice on finding the right adventure vehicle sub $5000
ExplorerTom
Which SUV's have a rear LSD and center lock differential?
Correct me if I'm wrong, but don't all 4x4s with a 2 speed transfer case have a center diff lock in 4lo? In my experience, in 4lo you will get power to at least one front and one rear wheel at all times.
BEG
Having a center diff lock requires a center differential, which part time cases lack. True, the net effect of a part time case in 4H or 4L is the same as a locked center diff: at least one front and one rear will turn. But vehicles with center diffs have the added feature of full-time 4WD for slippery on-road conditions, where all wheels can get torque and all diffs are open.
I browsed through this thread and didn't see the R50 Pathfinder suggested yet.
You will likely pay no more than $3K, most likely less, and get a 4x4 with all the bells and whistles (LE) while having a reliable engine, cheap parts, 4 doors, lockable rear solid axle (aftermarket). Comes in 3.3 or 3.5 V6. People will often tell you that these things will go anywhere, even without modifying. Once you lift and add all sorts of stuff, they are pretty fun. Only real downside, not much aftermarket support. But that didn't stop me!
Sent from my Pathfinder
XJLI
wow, thank you everyone for the responses.
My dads 01 Montero XLS went through a hydraulic brake booster assembly which was not cheap. We received a good discount as we have a buddy at the dealership. While it's a great vehicle, I can't get over that engine. It's very weak and needs atleast another 75-100 horses.
I like the suggestion made by Vistacruiser of the V8 WJ. I was reading up on the quadradrive system and it looks real robust, also the 6500lb towing capacity will do for my needs.
I can remove the rear locker from my list if there is atleast a rear LSD and a center diff I would be good with it. When I start off roading i'll consider a locker for the front and rear. I don't see the point of having a open front diff and a open rear diff and then being coupled with a locking center diff, I might possibly get 1 wheel to get me out of a jam? Someone correct me if my thoughts are wrong.
My $.02...
Figure out what you want the truck for. Within your budget (being that I'm also in NY and what you can get for $5k) I see two, maybe three "genre" choices:
Just a 4x4 to tow and get you out of the snow? You want a Tahoe. A small lift and good 32-33" tires with the V8 will get you out of almost any snow. Reliability is great, and replacement parts are CHEAP.
Something to tow with, and get into offroading and maybe build up: You want a Jeep. WJ/WK with the V8. Won't tow as well as a full-size but can work. Aftermarket is essentially limitless. V8 Jeeps aren't the most reliable things on the road either (not bad, but not older straight six Jeep reliable), and most are getting up in mileage at this price point.
$5k will get you into a 3rd gen 4Runner with mileage in the mid-high 100s. Better deals show up every now and then.
You're over-thinking the open diff thing, and (honestly) don't seem to have the best grasp of what actually goes on in 4x4 systems.
read this: http://oppositelock.kinja.com/a-4-wd-what-is-awd-4wd-and-how-does-it-work-1650386909
Any of the Jeep or Dodge vehicles utilizing the NP242 transfer case would have a center diff that is also lockable.
BEG
Yup, the NP242 is a full time 4wd case. Most jeep guys seem to get rid of their 242 for a 231 or similar part time case which is a downgrade for overland, IMO.
Bobzdar
Late year grand wagoneer hits everything except rear locker. They could be had with a trac-lok (limited slip) rear from the factory, but not a locker. However, given they had dana 44's front and rear, there is every manner of limited slip or selectable locker available you can think of. Tow rating is 5000lbs with 750lbs tongue weight and can seat up to 9 in a pinch if you buy a rear facing seat for the cargo area. If well maintained, mechanically they are pretty much bullet proof due to the simplicity and heavy duty components (727 trans, np229 transfer case and d44's front and rear). The np229 is an awd case designed so it can be run full time, but is locked in 4 low.
Electronics can be an issue but it's usually ground/connection (read: moisture) or PO related (see below), not inherent issues in the electronics.
I was in a similar quandary and that's what I landed on. I do have a lot experience with Jeeps and have learned one very important thing regarding reliability and buying one - if you buy one that has been modified, you will have reliability issues. Luckily the GW's are usually ruined far less often than their CJ and wrangler cousins, but beware. I also have a YJ wrangler that is bone stock (you know how hard that is to find now?) except for the exhaust and a warn winch that I installed. In the year+ I've had it, guess what the only thing that went wrong on it was? You guessed it, the aftermarket exhaust...Specifically the exhaust was not aligned properly with the mounts and it put enough stress on it that it cracked the muffler case. If you buy anything modified, be prepared to live with the PO's sins and a less than reliable vehicle.
BIGdaddy
find the lowest mile, cleanest version of whichever rig suits your NEEDS. (i.e. if you have kids = 4 doors + back seat)
BIGdaddy
Hello everyone,
looking to go get some advice on getting a lite off roader and snow monster. Currently we just had 3 feet of snow and would like to be able to go out without thinking twice. I was considering a '99 4runner limited as it has the rear elocker and multi mode awd system but highly doubt I can get it for $5000. I have also considered Wranglers but are not too fond of them and prefer 4 doors. My father has a 01 Montero xls while it has been good the repair bills are really high.
Here are my some must haves:
-sub $5000
-rear locker
-able to go through high amounts of snow with ease.
-4 door
-low maintenance cost
-reliable
-able to tow greater than 4000lbs.
-no pick ups.
Thanks,
Mo
Oh, and my 01 trooper meets all those needs if you consider a G80 limited slip a locker. (I know, I know, it's not, but it's honestly very effective and transparent on the street)
-Plus it has A/C, leather, heated seats, folding side mirrors, 60/40 rear seat, low range, and lots of ARB aftermarket support. :) I'm happy. Just beat the snot out of it this weekend in the desert and it never flinched.
Ducky's Dad
"G80" is a GM options code that indicates either an auto locker or a limited slip, depending on the vehicle. My GM truck has the G80 locker and my GM SUV has the G80 limited slip, but both have the G80 code on the build sheet in the glove box. Clearly the same code on both but not the same diff. Did Isuzu actually use GM differentials?
AdventureHare
Outfitting for Adv
Actually, "G80" is the Eaton designation, and it has appeared in GM, Volvo, Kia, Isuzu, Dana, etc. axles.
Ducky's Dad
Probably true, but GM uses that designation as an option code on their vehicles, and some of their G80s are apparently Eaton lockers, while others of their G80s are just clutch-pack limited slip units. Is Eaton making the LSDs for GM or just the lockers?
BigSwede
The Credible Hulk
G80 is an option code, can be different mechanically depending on make. The Isuzu G80 code means a Powerbrute clutch plate LSD, which is mechanically different than the GM one.
BigSwede
The Credible Hulk
Maybe a Honda Passport or the Acura version? I think they were available with lockers. A friend has one and it is his hunting/fishing truck, goes just about everywhere and tows a decent sized boat on occasion.
A Honda Passport is a rebadged Isuzu Rodeo. An Acura SLX is a rebadged Isuzu Trooper. Neither had factory lockers available, but many had a rear LSD. Look for a G80 code on the firewall option plate.
oskarf150
