Aero's 1999 Cherokee Limited
AeroSynch
So back in August I was able to finally buy the Cherokee I wanted due to Financial Aid Refunds from college. A 1999 Jeep Cherokee Limited with leather interior, power everything, and sun roof.
Here is when I first got it:
And the floor in the driver's side (the only hole, but still!)
Shortly after, I bought a 2" BB with spacers and rear AAL, and this is how it sits currently minus the bumper:
It rides like CRAP feeling every bump in the road, death wobble, etc.
Now, it is that time of year again where Financial Aid Refunds come to place, and I am planning on fixing the suspension.
I ordered a Rubicon Express 3.5" Super Ride with their stabilizer and adjustable track bar, and Bilsteins all around:
Also, I have ordered a few more things:
#784 Injectors
Rampage H4 Housings
H4 Wiring Harness from LMCTruck.com # 36-3580 as seen in this thread:
HD Headlight Harness write up - Jeep Cherokee Forum
Dual XHD7714 HD Radio
Nates4x4 Winch Bumper:
Now the waiting for the goodies to arrive.
AeroSynch
Thanks man!
Got my Rampage H4 housings today. The upgraded wiring harness should get here Wednesday according to UPS.
BIGdaddy
I think you're really gonna like that suspension kit. Two things though:
-If the RE sway bar disconnects get noisy(clunks, clanks, etc), consider dropping $125 on a set of JKS Quicker Disconnects (or look around for used examples)
-On 1997 and up XJ's it's almost 100% assured that you're going to have to run a CV style rear driveshaft with a Slip yoke eliminator of some sort.
Google hack-n-tap for one style which uses your stock tailshaft. The other is made by several companies including Advanced adapters I think. It replaces the tailshaft with new housing, shaft, yoke, etc. , but requres you take apart you tcase (hack/n/tap keeps it together)
AeroSynch
I ordered a transfer case drop for now while I get an SYE. I will have to go the Hack and Tap way because I have the NP242 transfer case.
I thought this kit did not come with disconnects? :confused:
I just saw the extended links, but if it does, then great, until what you mentions happens. JKS for sure.
BIGdaddy
ah, 10-4 didn't know they sold non-disco kit. That'll work fine! If you find you need more flex after driving it for a while, then maybe upgrade. I tossed my rear sway bar, and seem to have more than enough flex for the stuff I do.
As for the tcase, you're right, you're limited to the HnT kit. Might look around for someone upgrading out of their Np231 w/ sye. There's always a few for sail on naxja, and it would bolt right into your rig. (unless you're smitten with the np242. It's a good case, for sure, just not much aftermarket)
You are also able save a bit of coin and go with a rear driveshaft in front, but a nice "fit to your truck" dshaft is probably a slicker way to go.
Cool build so far. I like your mod choices. Should be a great all-around rig when you're done. :)
AeroSynch
Thanks man, that does look tempting, but I am going to have to hold out for now. Sure the NP242 is not really needed in Miami because I rarely use the Full Time function, but it is pretty cool because it is rare down here.
The idea was to have a good all arounder with this Jeep. It is my daily driver anyway back and forth to university on the highway.
BIGdaddy
Totally. It's a good case, so why not, right?
Look forward to your installs, brother.
Cheers!
-B
AeroSynch
Just need to put my rear shocks in and sway bar connectors. Besides that, the suspension is pretty much done. Only pictures from my phone. More photos later.
Starting:
Finished:
alexfm
Starting:
Finished:
Im liking the pile of "spare parts" sitting in front of the Jeep. But Its a nice lookin rig you got there.
bldeagle10
another route with the tcase would be, quadratec sells full np231 t-case's with a SYE installed already. if i remember right it isnt to expensive, if i remember right there may be a core charge for an np231 but idk i looked awhile ago. just an option.
i like the look of your xj, i wish i could use my financial aid on my jeep :/ but its my first semester so its all getting spent on a laptop and such...next semester though.. ;)
Black Dog
Makin' Beer.
Isn't college financial aid suppose to be used for stuff like tuition...books...living expenses...stuff like that?
Mcoleman
