To start of with, I have a 2003 awd Astro with 3 1/2" lift in the front and about 4" in the rear. I have 30" AT's on 16" stock wheels and new Procomp shocks.
80% of the time I drive my van with little or no load and it handles beautifully on and off-road. But, the other 20% of the time the rear of the van is full of gear, and the van rides like a brick down stairs. The ride seems to be at its worst going up steep bumpy hills.
My question for all the van guru's is, should I go with air shocks on the rear or maybe all four corners, or install a set of airbags in the rear? And why each one is better or worse?
On a side note, I have all the major parts for an on-board air setup (compressor and tank) I just have not gotten around to installing it.
Thank you,
Rotor
Thank you,
Rotor
