Air Pressurized NATO Jerry Can pump.
Co-opski
crusader
Cool--They have ones that'll fit Scepter cans too!
Lot's of good gear in Austrailia, which is great for Austrailians. Not as great for the rest of us. ;)
Beowulf
I've seen other versions for Blitz cans as well. I did not know they were available for NATO cans.
Scott Brady
Founder
I cannot see the justification of complexity. The super siphon is just such a great tool from my experience.
Where do you currently store your fuel cans?
rusty_tlc
It would certainly simplify matters if you couldn't get the can higher than the vehicle tank.
And it seems pretty simple just an air line in and a pick-up tube out. It wouldn't be rocket science to build one.
tremors834
I agree, the super siphon is is convenient, easily packable, light and works great. But that air pressurized thingy is just plan cool....... plus, cool gadgetry might make me look like I know what I'm doing out on the trail... At least to those not in the "know" LOL
mikelite80
How about something like this for a simple running water setup? I usually just put them on the roof rack and use a super syphon with a little ball vavle. Works pretty good but this could be a little step up in coolness.
Mike
crusader
Mike
That's exactly what I was thinking--Easily pressurized water for hot showers, etc. using my Scepter water cans.
Then I remembered that the Scepter fuel can has a different size lid than the water cans...
Far far north
Looks cool, but as said before complex.
I've used something somewhat similar, it has a pump instead of the need for compressed air.
Think it's a NATO item.
I've used it on my boat and to run generators.
But it doesn't flow as much as the pressurized thing or the supersiphon.
If I was gonna build a transfer system for water for showers and stuff I would just use a washer pump from any old car.
Co-opski
In the bed of the truck and I use the win-door of the shell to access the cans with the Super Siphon. It just looked cool for the on-board air capabilities.
Funny everyone was thinking of shower systems. That is how I found the company. The cabin I live in is dry and off the grid and I use a Blue 55gal poly drum with a Shurflow water pump hooked to a car battery for the pressure shower system. Seriously I'm not that much of a dirty hippie. I'm tired of the battery and was thinking of an air system for the home shower. I'm glad the coldest part of the winter is over there was a week it was iced up solid.
crusader
Used for showers, etc...It's really not that complicated...It uses a schrader valve for the air inlet, the same as tires. Add one hand or foot pump for a bicycle tire and your shower could be pressurized well beyond what a windshield washer pump could ever provide on its best day.
I agree about it being unnecessarily complex for getting fuel from a jerry can into a vehicle fuel tank unless extenuating circumstances exist. Who's got the time to hook up everything just to get 5 gallons of fuel from a very portable jerry can into a truck's tank.
Co-opski
I like that style with the primer hand pump like ones used on boats.
BTW welcome to ExPo!
rusty_tlc
That could be cool.
I suppose my main concern is over pressurizing, leaks, safe relief of pressure, etc.
A simple $12 pressure regulator from Harbor freight would do the job.
I wonder how much pressure a gas can generates just sitting in the sun? They hiss pretty loud when you open them.
crusader
Features, as copied from the manufacturer's website, include a pressure relief valve:
No moving parts
Runs with 12 V air compressor, foot or hand pump
Powdercoated body resists corrosion. Red or Yellow
Empties a Jerry Can in minutes
Tested with Petrol using 72 LPM 12v "Max Volume" air compressor
Specifications:
No internal moving parts
Operates with air pressure as low as 2-5 psi
Air inlet : Schrader Valve
Safety : Pressure relief valve
Outlet : 10 mm pipe with 2m fuel grade hose
For low pressure/volume 12 volt air pumps
_______________________________________________
