Another ambulance build...
It's a Fanbulance now! Your shop us huge and awesome, good luck with the project. And, the kegerator is a nice winning touch.
thanks!
the mirrors are newer van towing mirrors. they look just like superduty mirrors but have mounts for van doors. to fit them on the older doors i had to drill 2 new holes and then make spacers to take up the slack in the studs.
thanks! the shop is a disaster! I never have time anymore to hang out there and if I'm not around nobody takes care of my ****!
Wow, that has to be the fastest ambo build!!! She looks awesome and yes, I'm jealous of your shop as well!
Well done!
Mr. D
How are you liking the 6" lift? I'm debating between 4" and 6". Chris has said before he suggests 6";
Posted by ujoint
6" on 35's is perfect in my opinion. Good wheel travel, tightest turning radius and we can run a trac bar on the front. Things are too tight with the 4" lift. (Clearance between the axle & engine x-member.) We also can't run a longer pitman arm because it will hit the spring pack at full lock left.
HButton
