brianjwilson
Some sort of lost...
I'm sure you did the measurements to verify, but I was under the impression that the articulation of the leafs was the limiting factor in how much rear wheel droop you could get. If that wasn't the case the shock would essentially be your limiting strap which would almost certainly lead to premature failure.
Reason I asked about the sway bar was I wasn't sure if you installed the drop brackets. Granted the geometry may not play the same as with OME but I had a bit of interference running the lift with the sway bar in the stock location.
Oops missed that. Yes I installed the sway bar brackets.
