Any interest in 4m50 egr block off plates?
boostin
So I am still going to build something but I guess I need to know what people like.
I was thinking a 1/8 thick sandwich plate you squeeze between the cross over pipe and the exhaust manifold
And/or 1/4 thick plates that cover each end of where the cross over pipe mounts
jhrodd
I would definitely be in for a pair of 1/4" plates !
pugslyyy
It's not a technically challenging mod. I think the biggest issue I had was getting all the bolts out that hold all the EGR apparatus in place. I was able to re-use the gasket on the intake-manifold side, but had to replace the exhaust-manifold (3 hole) gasket.
Also, the coolant inlet pipe for the EGR cooler will bolt directly to the motor making the coolant bypass pretty simple.
boostin
Just a heads up, I am making plates as we speak, a Set of 3/8 plates to replace each end of the cross over pipe and a 1/8 plate if you want to sandwich it in the manifold side and keep the cross over pipe for appearance that you still have emissions
Any one interested, please e mail me miketeierle@gmail.com, as I don't get on here much
seth.c96
