Hi folks. I am the XVENTURE product manager from Schutt Industries. If you have any questions I am at your service. I'l do my best to chime in here as often as possible.
I saw they have a trailer just marked under 10k with an ARB RTT, awning, awning room(I think) and chairs. Pretty cool packaged deal if I'd say so myself. If I didn't have a TD I'd jump on that deal since I'm too lazy to build my own set up.
Hi Twinstick, I'm a little slow to the keyboard but I do get there. Attached are two pics of the passenger side front compartment on the XVenture2. This is the electrics side. The center section is set up for gas cans, the driver side for the ARB Fridge. The single cylinder ARB compressor, the Goal Zero, the second battery, and the pass throughs for 110 and solar wires are all in the pic..
I read your requirements above, they are quite high. The trailer is quite capable of filling your needs, you'll just have to configure it a little differently. I use 2 50qt ARB fridge instead of one large one. One in the trailer and one in the Jeep. As noted, we are truly happy with the performance of ours. We're gone again on Friday, Arizona calls.
Bob
slsbl77, & Markimus
Thanks for the pics. Please bear with me here. Is that Goal Zero also a/the 12v battery ? If not, where are the battery/ies ? Also, have you used the arb single compressor much ? Curious how well it works. I figured i would need the arb dual compressor & an air tank for quick tire repair & refill & probably most certainly for an air impact, to also aid in quick tire changes on truck or trailer (side of the highway repairs are dangerous).
The pic shows the Goal Zero 400 battery and my second 12 v battery is directly below it. I am using an Odyssey 1200 series for the second battery, I got the one with side terminals to avoid the possibility of it bouncing up and shorting. It is also closer to the rating of the Goal Zero, my feeling is that 2 batteries of similar ratings will be happier working together than one large capacity and one small. I also think the smaller ARB compressor will be fine if you are going to have a tank, a 3 gal tank would run an impact. Personally, I would just get a Craftsman battery impact, 200 lb. model. For repairs, you will only be removing/installing one wheel.
When I air up, I find the ARB single to be fine, the chuck they supply hooks on, so I set it and walk away to do something else, you do not have to hold it in place.
We can go for a week easily with the 2 fridge setup, more really, depending on what meals we choose to make. We use both as fridge. I carry 10 gal of gas in the AEV fuel caddy, obviously we have 22 gals of water on the trailer and capacity for 10 more in the front cabinet.
Getting ready... : ) Bob
