Stroverlander
Astro AWD "Stroverlander" Build
Introducing my 2004 Chevy Astro AWD - Stroverlander as it sits now - 4" lift, Rancho RS9000XL shocks, Yokohama Geolandar A/T-S 235/70-16 tires, G80 rear diff & 3.73 gears.
Here is a before shot with worn out stock size 215/70-16 tires.
Another before shot with new 235/70-16 Yokohama Geolandar XL load rated tires, loaded down as it often is. Definitely needed some attention!
Outside a friend's shop after a bit of welding:
The journey started out with replacing just about every component in the front end at 128K with Moog chassis parts due to being super loose and worn out tires.
Performing the work myself (sans balancing and alignment), I replaced upper and lower ball joints, inner and outer tie rods, obligatory idler arms, center/drag link, axle shaft seals, sway bar links and bushings. I can't say enough about the quality of Moog chassis components I purchased from Rock Auto - perfect fit, great quality and lifetime warranty!
This is my second set of Yokohama Geolandar A/T-S tires (in 235/70-16 XL load rating up from stock 215/70-16 SL) on this van and a great all-around tire for the money - excellent grip both wet and dry, quiet and good mileage. I got approximately 46k out of the first set on road and could have been better had the front end been in better shape and not had excessive inner edge wear.
With the front end tightened up like new, aligned and new Yokohama tires installed, I happened across a used OLV 2" lift kit for sale on another forum at just the right time. The kit was a great price and I've wanted to do these modifications for a long time, even with my previous '97 Safari AWD, just never the right opportunity.
If you're not familiar, the OLV 2" lift kit includes 2" body spacers for the front subframe with hardware, bumper relocation brackets, emergency brake cable relocation bracket and adjustable rear lift shackles (with urethane bushing with grease fittings). The kit arrived in great condition, the only thing required was replacement bushings for the shackles as the previous owner had done quite a bit of towing and so the bushings were worn out. I was able to source replacement bushings from both Gerald at Overland Vans and airbagit.com which are what is included in the OLV kit.
With Airbagit being a bit quicker on the draw to respond, I ordered up new bushings for around $30 shipped and installed the new replacement bushings with no problems. While waiting on the bushings to arrive, I removed the fan shroud and trimmed the lower piece the appropriate amount to clear the fan with the body lift and reinstalled.
The OLV 2" kit was a very straightforward install and luckily for me my van is relatively rust free having lived most of it's life down South so no problems with rusty or seized fasteners (knock on wood!). I started in the front by removing the grille, bumper cover, bumper bumper brackets, loosening the six subframe bolts and then jacking up one side at a time to insert the body lift spacers and longer replacement bolts. I was really surprised at how quickly the process went for both sides and the setting the front back down to Loctite and torque the subframe bolts. From there, I installed the bumper relocation brackets which bolted up perfectly and reinstalled the bumper cover and grille. I was doing this outside and it was raining pretty severely at this point so I hurried it along without taking any photos but has been documented well enough elsewhere.
Next up, I installed the e-brake relocation bracket, again a straightforward affair and moved on to the lift shackles. Removing the stock shackles and installing the (well greased) lift shackles turned out to be a piece of cake as well. Only a bit of finesse was required to line up the shackles in the bottom hole for the max amount of lift.
Upon completion I took measurments front and rear (ground to fender lip) and ended up with the following (after adding one turn (approx 1/4") to driver's side torsion bar to account for a bit of sag)
LF 33"
RF 33 1/4"
LR 34 1/8"
RR 34"
Here is the van at the 2" OLV lift stage, pre test drive:
After inspecting for tight cables/hoses or any sort of interference and a test drive I needed to perform a few small modifications. The biggest one was having to trim the front bumper cover and relocate the lower mounting brackets to clear the tires. No big deal, I used a Dremel with cutoff wheel and taped off the bumper cover for a guide and proceeded to trim the cover and used a hand deburring tool to clean up my work. I had to reform the brackets and drill new holes in the bumper cover to mount the brackets.
I also noticed the upper coolant hose and throttle cable were sandwiched pretty tight between the radiator shroud and airbox so I decided to relocate the throttle cable over the upper coolant hose and trim the locating nubs off the top of the shroud which hold the hose in place. This allowed everything more room under the airbox to keep from pushing it up and a suitable angle for the throttle cable.
At this point, I was happy with my van, it drove well, especially with the Bilstein HD shocks I'd been running for the past 30k and I had a decent amount of lift. I did have a bit of vibration from takeoff to about 20-25mph after installing lift, but nothing too serious.
Pretty basic "camper" right now with inflatable air mattress, cooler, MSR Whisperlite Int'l stove but gets the job done and sleeps comfortably!
to be continued...
LF 33"
RF 33 1/4"
LR 34 1/8"
RR 34"
to be continued...
