Martyn
AT has designed an aluminum bracket for a 10 lb propane cylinder.
The brackets are made from 1/8" thick aluminum and have rubber bump stops to hold the cylinder off the bracket. The cylinder is held in place by two stainless steel T Bolt clamps. There are pre-drilled holes in the bracket.
Size: 12.375" T x 9.5" W x 4.75" D (314mm x 241mm x 120mm)
Weight:2.5 Lbs (1.13 Kg.)
1/8" Thick aluminum
Two Stainless Steel brackets
The 10 lb propane cylinder that fits into this bracket is 17.4" tall x 8.9" in (442mm x 226mm) diameter and holds 2.4 gallons of propane. The bracket and cylinder combined weight is 17 lbs.(7.7 Kg) and it is 18" tall (457mm) with a maximum diameter of 10.5"(267mm).
The bracket is $119.95 and is available through our web store or by contacting us directly.
1/8" Thick aluminum
