Hey all. I have a bit of an odd jeep which I am going to build a camper for. It is basically a FSJ chassis with a bobbed CJ body and a steel hardtop split into two pieces. Anyway I am at a cross roads with the design. I am trying to keep it as small as possible but just cannot fit everything into a 2.5x1.5m area. So I either have to make it wider or longer. Wider it would be sticking out past the cab on both sides risking not fitting down trails and makes the front corners very vulnerable. Longer means an overcab design, something I have being trying to avoid. In the normal configuration this means a fair amount of added height which is very vulnerable to branches and such and a higher centre of gravity and more wind resistance.
So what I have thought is if I remove the hard top I can build the camper attached to the back of it. This means I can put a bed over the cab with a very small gain in height. It also means if I fabricate a swivelling seat mount I can use them as internal seating, saving even more space and cost. I can still make it removable so I can slide it off at a camp site and make a soft top to cover the cab where it is missing.
However what I am wanting help on is mounting the camper. If it is solidly mounted to the body which it has to be in this design then it needs to flex with the body instead of the chassis which bears most of its weight. I doubt this chassis would have as much flex as a truck but I have no way to test it and don't want to run into problems later. So how can I design the camper to not stress the body? My initial thoughts are to do a 3 mount system with the two mounts at the front but it will still have a gap of about 0.5m between the body mounts and camper mounts. I do not want to modify the chassis to move them either. Otherwise the camper would have to be somehow made flexible to twist with the chassis.
Any ideas?
Thanks.
Any ideas?
Thanks.
