Aussie locker + center diff lock
Klierslc
When one wheel slips on the ice it locks up the auto locker, then causing both rear wheels to slip on the ice. I have an aussie in my 97 and like it quite a bit. It is nearly unoticeable on road and very nice off road. My previous two 80s were triple locked, and I liked that better, but for long term durability and ease of repair, the aussie wins out.
For rusty's question--I would not drive a double autolocked anything on road in 4wd, especially not on ice, loose snow, yes, but that is about it.(unless the front was a truetrac type LSD)
In your situation, the 80 rear axle would still lock up and slip, but the front axle would be pulling you through the turn. As long as you aren't on the throttle hard, as soon as the front starts to pull, the rear will unlock. If you stay on the throttle, the rears will push the fronts into severe understeer and you will go straight instead of turning.
rusty_tlc
Kerry: What Klierslc said, once the axle locks both wheels are spinning. With an poen diff one wheel will spin while the other "anchors" the truck.
Klierslc;
Yeah the 60 is pretty much a 2WD vehicle in winter, on pavement anyway. One time doing spins on the street was enough.
The 80 question was academic, I don't even own one. I was just wondering out load.
kerry
I'd like to here firsthand experience of people with the aussie locker in the rear in an 80 series with a viscous coupled center differential. Seems like an auto locker in a vehicle which regularly traveled on icy roads might not be a very good idea. What are people's thoughts on this?
Klierslc
It is a non issue. I have been driving in Northern VA for the last 3 months on icy roads, and as I stated above, as long as you don't hammer the throttle while turning on ice, you will not know that it is there. I have to work hard to get my 80 to drive differently than it did with an open diff....
See the 80s section on ih8mud if you want more positive reviews of the Aussie locker in VC 80s....
zhukoveli
