SDDiver5
Hey Expo Fam!
Recently got an Aux Beam switch panel and I have some lights and a few other things to wire up. Right now the lights are a set of BD XL Pros and some S2 chase lights.
Wiring is not a strength by any means and quite frankly it seriously intimidates me.
So here’s what I have
Pretty simple, right? False!
Everything looks pretty straight forward as far as mounting, wiring the lights to the control panel, mounting the switches, etc.
My question is regarding this guy
Now, I know it’s an add a fuse. My question is where does this go? It’s meant to power the switch panel. It looks pretty simple but I’m absolutely over thinking it. If my research is correct, it should go in the fuse box for simplest installation, correct? Would the fuse box under the hood or In the cab be preferable?
Since the fuse is 5 amp, do I need to find a 5a ACC spot to put this on and go from there? Overloading wires is a big concern and I’d prefer to not watch My truck burn due to an electrical problem….
Hoping some of you electrical guys can help me out. Please use normal English and not electrician talk because I’m dumb. Learning about the this stuff is a goal of mine for 2022 and I feel this should be an easy first project.
So any advice, tips or videos (specifically my generation f150) would be awesome.
Thanks!
Mods: if this would be better suited elsewhere please move it!
Thanks!
