TrainingWheelz
Hey Vanning ExPo'ers! First thread from me, but long time reader. There's a lot of great info and stories on this site!!
I have a hi-top '97 AWD Astro that I'm working over into a much more comfortable rig for weekend ski trips and other adventures. After quite a few ski areas parking lot nights without a real heater, I have come into both Espar hydronic and airtronic units for FREE! (no controls or plumbing included, but they can be sourced separately) Not sure yet whether both or one will be installed - cabin heat for airtronic, hot water and block heat for hydronic.
But before either can be installed, need to figure out how to fuel the units with diesel in a gasoline powered van. I'm not going to need more than a couple gallons at a time so not interested in a large undercarriage mounted tank and probably don't have the space for that anyway.
What have other people out there in expo land done to solve this?? As diesel isn't explosive I was thinking about mounting a RotoPax to the rear door (like your standard jerry can mount) and run a small, protected, fuel line into the vehicle. I'd prefer not mounting a tank in the vehicle for spill and space reasons. There are small aux fuel tanks that could be mounted under the chassis, but refilling will be an issue as I'd prefer not adding a fill spout. With those constraints, seems like an rear mounted tank may be the best option. Any significant drawbacks to this? The tank could also be mounted to the side of the van to eliminate the interaction between the moving door and fuel line.
PS - with a hydronic unit, is a 12v water pump required to use the unit for hot water with a flat plate heat exchanger? Gravity feed may work but you'd need a high up mounted tank.
TGIF!
TGIF!
