[AZ] 45 Gal Aux long range Front Runner gas tank with OEM Dual Filler for FZJ80
OverlandTheWorld
OverlandTheWorld.com
Fellow ExPo enthusiasts,
I have a 45 gal Front Runner Aux Gas Tank for a FJ80 or FZJ80 available. These were sold by www.campinglab.com/fueltank, but are no longer imported. It comes with everything I received from the kit as well as a VDO gauge & OEM petrol filler neck. The Instructions are a little vague, but you can find better write-ups on MUD. I purchased this 170L Aux long range tank from another Mud member. I decided to go with a water tank setup in the spare location instead and have not installed it. I do not know if it is 100% complete, but it appears so. It is in like new condition.
The Bad:
The transfer pump looks puny, I would upgrade it.
Instructions are lacking
The filler neck it came with is not the best (however, see below)
The Good:
I purchased a petrol OEM sub-tank filler from AU to use instead of the one provided in the kit. This by itself is fairly hard to find and worth it. The pull handle needs to be purchased from a local dealer or Akella on MUD
Comes with VDO gauge
Sender, hoses, hardware
Tank located in Phoenix, AZ. Shipping is on you but figure $100-150 to cross the country. Asking $950 or trade for other 80 parts, expo gear, or ammo.
Jeff
*UPDATE - Somebody mentioned that this may also fit the 100 series, IDK, but worth looking into. Also, Alu-box in pics is not included
Photo Jan 28, 4 59 49 PM.jpgPhoto Jan 28, 4 59 38 PM.jpgPhoto Jan 27, 2 08 22 PM.jpg
iStan814
