Bantum M100 Fenders...Need Wider Pieces
rxinhed
Dirt Guy
Sources for wider fenders? I'd like to install my 33x12.5" tires on 10" rims; however, the little fenders don't have enough cover.
Thanks.
Tumbleweed
Early CJ 5 rubber fender flares fit perfectly on the M100 fenders. You can also weld a band of metal into the fender very easily to widen them.
Box Rocket
That's what I did with mine. However, mine are standard trailer supply fenders not M100 fenders. The radius is the same and the CJ flares worked perfectly. I needed to trim some length off the fenders but that was it.
Helped covedr my 33's well
FiscAnd
