Bench Storage Kit for Camper Shell / Flippac **SOLD**
WASURF63
This is a custom built modular benchseat storage for 6' Toyota Tacoma longbeds; '05- '11 ( or similar truck bed dimensions), Bedrug kit, water tank/shower set-up, and Hassock toilet included.
Dimensions: 54.5" W x 69.5" L x 16.5" H, 27.0" H at the fridge/table compartment (fits Engel MT45).
It lived formerly within the walls of my AT Flippac. Since the Tacoma & ATFP have both been SOLD I'm offering it at a reduced price from what it cost to put together.
There is also a removable, carpeted panel insert (not pictured), that installs over the walkway turning the bench storage into a platform (ie..single sleeping area; approx 6' x 3').
There are 4-storage trunk compartments and 1-fridge/freezer compartment with a sliding lid/table/cook surface. There are (4) D-rings and (4) turn buckles to secure the fridge unit to frame.
The large forward storage trunk houses the 15 gl water tank that has a 12v / 1gpm pump to shower sprayer hose and a seperate gravity drain hose to the exterior passenger side wheel well. The 12v pump is wired to a remote switch that was located just inside the windoor of the Flippac (I also stored all my camp kitchen stuff here.)
I used the side/mid compartments for clothing and dry food storage.
The rear driver side compartment was utilized for the Hassock toilet.
Although designed around the Flippac it would also work in any 6' longbed Toyota Tacoma; 2nd gen '05-present. (or similar dimension truck bed with a high-rise shell).
The three individual benches weigh about 40 lbs each and are connected together via two lag bolts and then secured to the rear bed
D-rings via turn buckles. The entire set-up can be installed / removed in 10-15 mins.
It's built very solid and does not move once secured.
Below is what it cost to build:
3-PIECE REMOVABLE
MODULAR BENCH
STORAGE SYSTEM > 300.
BEDRUG KIT > 200.
15 gl WATER TANK > 200.
w/12v PUMP / REMOTE SWITCH
@ WINDOOR for (SHOWER)
and GRAVITY DRAIN HOSE
w/ SHUT-OFF.
3-RECEPTACLE 12v PLUG > 30.
>>> total cost to build > ( 730.)
Asking $200. OR BEST OFFER for entire set-up. **SOLD**
PM me if you are interested. I can also be reached at "wkbagnall@comcast.net" or (206)450-1738
Thanks for looking,
Walt
Attached are a few pictures, but my entire ATFP build can be seen here :
http://www.expeditionportal.com/for...F63-s-New-ATFlippac?highlight=wasurf+new+atfp
ETAV8R
Founder of D.E.R.P.
NOOOOOOOOO!
You have been an inspiration and helped me with ideas for my flippac. I understand the move to the FWC though. I would like to have one as well but don't have the money as of yet. Heck if I had the money,and you were parting things out, I would drive up there and take the interior build and goodies off your hands for you.
This is one of the best Flippac buildouts. Someone should jump on this ASAP!
Sfreeman
