I apologize for the mis representation from the beginning of this ad! I have had these laying around and never really bothered looking at the part numbers! I have updated the pics in the craigslist ad and the product specs! I am guessing one of the longer travel shocks had been replaced at some point and they found a replacement shock with relatively the same specs and same valving!
http://raleigh.craigslist.org/pts/4873086478.html
B46-0350R 1 Shock
Body Design 46mm ID Smooth Body(Non-Coilover)
Boot Included No
Collapsed Length(in) 19.53
Collapsed Length(mm) 496.0
Compression @0.52m/s 800
Extended Length(in) 31.10
Extended Length(mm) 789.9
Finish Electroless Nickel with Clear Powdercoat
Internal Design Monotube
Lower Mount Type 1/2in Heim
Rebound @0.52m/s 3600
Reservoir Yes
Upper Mount Type 1/2in Heim
AK7112R06 1 Shock
Compression: 800
Rebound: 3600
Collapsed Length: 19.61
Extended Length: 31.34
Lower Mount: 1/2" Heim
Upper Mount: 1/2" Heim
Reservoir: Yes
Reservoir Type: Remote
Body: 46mm ID Smooth Body (Non-Coilover)
Finish: Electroless Nickel with Clear Powdercoat
Coilover: No
Spring Seat: No
Manufacturer: Bilstein
AK7110SB06 2 of these Shocks
ollapsed Length (IN): 14.21
Extended Length (IN): 24.31
Travel Length (IN): 10.1
Compression: 800
Rebound: 3600
Shaft Diameter: 14mm
