Bizarre transmission leak... pressure issue?
redraif
The uphill battle begins
I swear I'm over this leak. We have been chasing it since we decided to get this rig back running.
2001 xls 4wd montero sport 3.0l.
History on the tranny:
When we bought the sport it had a bad transmission. We bought a new used one from LKQ. It was a low mile transmission. 60,000 if I remember right. At the next oil change I was told it had leak at the transfer case to transmission. Long story short. They refused to warrenty the seal and promptly were out of business. They blamed it on the transfer case. It was only a little drip and honestly with all the chaos of the other issues it got forgotten. It had a some massive oil leaks. We kept fixing things. Only thing left was a stripped oil pan bolt that leaked like crazy! The tranny leak became a non issue, I never saw drips, though the oil leak could have masked it. But the trans fluid level stayed fine and all seemed well.
Current issue:
It sat for over a year. I noticed some transmission fluid when we got it running. We took it in to the shop to ask him to check out the leaks. He sorted out the last oil leak, which was a stripped pan bolt. well we got it home and the trans leak was obvious now. I took it back and he said it was the transmission pan. Well finally last week he focused on it. I remined him that he told me it was leaking at the joint bw tranny & transfer case. He swore it was the tranny pan. So I agreed to due a transmission service. With my daughter taking it in 3 feet of mud before it was parked and having a trans light for a moment, I figured it was a good ldea. Well I told him everything transmission related needed to come from mitsubishi. So that's what they did. He pulled the pan and replaced the filter. Said the fluid was not bad looking at all.
So here is where things went sideways. He went to refill the trans once it was buttoned up. He said it called for about 5 quarts to refill after a service. Well it took about 4 then refused anymore unless you filled it really slow. He said it just sat in the funnel and did not move. He was baffled it took less then it called for, but went with it. He sectioned out the access from the tube and got it to the proper level then drove it and things seemed ok shifting wise. He checked it again and filled it slowly a few times and got it dialed back in on the dip stick. Drove it again and it stayed where it was supposed to. So he said it was good to go.
So we took it home. The 5 minute drive was uneventful. I jumped on it a few times and it seemed normal. Drove it thru a few slow accelerations too. Again all was well shift wise. So I parked it for the weekend.
Monday I took it to the bus station. Now this was a 10-15 minute trip one way. On the way home it must have started dripping tranny fluid again. It left a trail down the driveway. I slipped it's drip pan under and had a 2 foot puddle by morning. ******?
I looked at the rig from below. The whole side of the motor on the drivers side was wet. From the frame rail, suspension, steering shaft to the block. Not sure if it's from when he overflowed the tube or from what is going on now. He said he cleaned off all the spill, but i could not tell it. So i cleaned it up with 5 cans of brake cleaner to dry up the splatter and see if a trail showed itself on the way back to the shop. I took it back to him Wednesday morning.
So I researched an posted on the Montero Sport forum, but want more input.
The concensus is that he overfilled it and it was puking back out the tube once the trans got to proper operating temps. It did not show itself on the 5 min trip cause it was too short. The 10-15 minute trip got it hot enough and exposed the overfill. He must now have driven it far enough at the shop. Or is it an internal pressure issue?
The mechanic looked at it after I cleaned it and drove it too him. He says the leak pattern is consistent with it puking up the tube and leaking down and splattering rearward and down. He does not know why though. I told him it was a suspected overfill and he stated it read right on the dip stick. Well maybe the trans was not all the way heated up. Needed a longer drive and more shifting through the gears. He wanted to talk to a transmission guy who is his friend, but was open to my and the forums input.
So why did it fill abnormally slow? I discovered in another thread that there is a vent tube on the top of the transmission. Well maybe it's blocked, dry rotted, or melted shut. Could it be causing abnormal pressures and causing the tranny to puke fluid as it vents pressure out the tube as that is its only exit besides the vent? I mean if you think about it.... old portable gas cans had a vent you open when you pour gas out of the spout. If you forgot the gas glugged as air was having to move in the same hole to equalize the pressure. So potentially if the vent can't vent, the fluid had to go slow and glug down the fill tube as air bubbles passed the same space going up?
I hope my crazy explanation makes sence.
One posting in another thread a guy stated the sports have been know to have transmissions overheat when the vent fails. This has been known to happen due to the vent and manifold being too close to one another. The vacuum line part of the vent melts shut.
Now my tranny has never overheated, but I have also not pushed it hard & it's been cold here also.
Any thoughts you guys? Ever had one puke back up its tube? What could it be? Does my possible vent failure senario make any sence? I told the shop about it but he has yet to check the vent. He says he is still waiting on a call from the tranny guy. Ugh! Is it that hard to check the vent?
kpredator
X2 on the vent,once my work rig was dripping trans fuel ,after burying it door deep in mud.got pulled out by
a wide pad d6. Mud had gotten over top of transmission while being pulled.
Good luck
Kp
redraif
Spoke to the mechanic today. His trans guy said to drive it with a scan tool to verify it's not overheating or doing anything else weird. Trans guy says he is probably going to need to add an external trans cooler. No mention of a vent or overfill. Just pushing the overheat issue. The vent was what folks mentioned being at fault in some overheat conditions. He swears he will check it. Not sure why he did not check it already.
Possibly the vent is plugged due to your daughter getting it stuck in mud. I would check the vent.
Good luck
Kp
I reiterated the potential blocked vent issue due to it going in all that mud. Daughter's boyfriend took it for a mud bath... thanks never conected the 2 till now. They got it stuck and it had to be towed out.
redraif
Ok.... I got a sick feeling yesterday after talking to the mechanic and could not sleep. He was dead set on checking it on the scan tool first. I'm sure cause it means more cash from me.
I was so worried he was going to run with the overheat possibility and push for a auxiliary transmission cooler and ignore the vent. Not sure why he will not just look at the vent. I know he did not tell his trans friend it was in 3 feet of liquid mud.
Anyway... I was up till 5am... I decided to search clogged transmission vent on google. Would you believe that the symptoms are identical to mine. Trouble filling the trans with fluid and puking up the dipstick. Just to help others I'm going to add links to this post of helpful links in diagnosing as well as links to threads discussing relocating vents higher for off road rigs.
Relocating vents:
http://www.wranglerforum.com/f274/e...h-pictures-axle-and-transfer-case-185089.html
http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?t=44164
Not montero sport specific but it should help!
Similar issues:
http://www.powerstrokenation.com/forums/showthread.php?t=110200
http://www.fixya.com/cars/t3201679-wont_any_trans_fluid
http://www.hotrodders.com/forum/transmission-vent-problem-153895.html
http://dmctalk.org/archive/index.php/t-1601.html?
http://autorepair.about.com/library/a/1/bl782.htm
https://answers.yahoo.com/question/?qid=20080218185813AA8Pai7
http://www.taurusclub.com/forum/87-engine-drivetrain/145655-what-transmission-breather-vent.html
http://www.cherokeeforum.com/f2/transmission-blowing-fluid-out-breather-tube-137925/index5/
http://www.chevelles.com/forums/showthread.php?t=146467
http://www.chevelles.com/forums/showthread.php?t=318145
http://www.ford-trucks.com/forums/1328070-tranny-fluid-coming-out-dipstick-hole-2.html
http://67-72chevytrucks.com/vboard/showthread.php?t=253267
http://transamcountry.com/community...bd1c8a3292afd9df3b1a828da2&topic=34873.5;wap2
http://coloradok5.com/forums/showthread.php?t=136272
This one had issues with the trans not taking the amount fluid he thought it should take. Nearly identical situation to mine. Part went in fine then it stopped taking fluid prematurely.
http://www.steelsoldiers.com/showthread.php?93814-M35A3-Transmission-overfill
So what I have gathered from reading... To check if you have a blocked vent. You can shoot compressed air down the filler tube. Under normal conditions you can feel air coming out the vent. If you instead get transfluid coming up the filler tube, that would indicate a blocked vent. If your lucky the air might push the debris out the vent! If no air comes out the trans vent, poke a wire in the vent tube hole being careful not to push debris into the trans. Never shoot compressed air in the vent tube towards the trans or you will blow crud into the trans. Commonly its dirt from driving on dirt roads, mud dobbers nest, bee nest, spider webs with cottonly balls. Well the truck went for that lovely mud bath and then sat for a year. It had quite a number of bees nests and mud dobber nests when we were cleaning it up to get it running again. So maybe!
It can also be other things like a bad Torque convertor, overheating, overfilling, filter disconnected from valve body or plugged up, pump failure.... So here are my fingers crossed for the blocked vent tube.
redraif
OK called shop today and got word back that he checked the vent line and indeed one of them was clogged up badly! I'm assuming the multiple vent lines checked would be the transmission and transfer case case lines. In researching, I read they both lay side by side on the top of the transmission.
http://msport97.proboards.com/thread/10570/transfer-case-slow-leak
Anyway... All the info was being given to me by the girl at the front desk, so she would have no clue which was clogged. So the plan is for him to now test it tomorrow to be sure that was the culprit! Fingers crossed!
redraif
Ok so the report today. Called the shop. The sport has been running and the mechanic has been checking in on it to see if the leak would return. So far so good. No leak and it takes fluid again. He is going to take it for a long drive tonight after hours to see if it maintains...
redraif
OK I called the shop. Mechanic said the long drive produced no leaks! So it was the crud in the vent tube! :) I hate I had to do a transmission service to find this out... LOL! But all in all it was a necessary step in the grand mystery. We had already planned on doing a service on it anyway after the mud bath.
So add to the preventative mod list... extend all my breather tubes up to safer ground! :)
Linesman1776
