Body type and finding an oil leak
devo 1
It is the EBV control. I have deleted it on my F350 and E350. On the van I plugged the control back in to the wiring harness and zip tied it out of the way. If not, it will leave a soft code in the computer. (no check engine light) Then I gutted the EBV valve out. While I was in that part, I used a die grinder and smoothed out the inside of the valve housing. I used this non ebv turbo pedestal: http://www.strictlydiesel.com/p-2660-non-ebv-turbo-pedestal-late-99.aspx
My oil leak was the non serviceable hpop plug. This guy sells one to replace it: http://www.dieselorings.com/serviceable-replacement-hpop-plug.html
devo 1
I fixed the hpop leaks from the back. Took the up pipes and turbo off to get to it:
devo 1
This is the only pic I could find of the gutted ebv. The ebv pieces are laying on the floor behind the up pipes.
gtbensley
Awesome thanks!!! It seems to be the sensor itself that's leaking....Not that it matters, the ebpv still needs to come out it looks like.
crostopher
