Broken Shock and Shock Mount on D1
Red90
Springs do NOT limit compression travel, or I should say they should not limit it.... If you want to limit compression travel you MUST add longer bump stops. If the springs do limit the compression travel, you will break something as the springs should not ever fully collapse.
Really if you drop stock shocks 2", you should extend bump stops by 2". In reality, due to geometry, you can get away with less.
Red90
The problem with suspension lifts in the Rover community is nobody sells proper kits nor informs customers of all the items that really should be addressed...
A 3" spring lift really should have...
- Springs.
- Adjusted shock mounts or longer travel shocks.
- Longer bump stops or bump stop spaces.
- Longer brake lines.
- Some form of castor correction...
- Driveshafts suitable for the lift and travel.
- Modified radius arms and trailing arms are a good idea at this lift level as well.
t42beal13t
- Springs.
Everything is there but the driveshafts and possibly the bump stops. I'll be getting driveshafts shortly.
V45W_Proto2.5
