BUILT LR3, about 3k miles on build w/expo trailer
speedpin
Wanting to start a project over the winter so need t free up the stable.
Once the rain let's up I will post full set of pictures.
$18,500 for LR3
$4,500 for trailer
Or package for $22,000
Located in Fredericksburg VA
2007 LR3
Off Road Equipment.
Proud Rhino Front Bumper
Baja Design Bumper lights (floods) work on the stock fog light switch.
JW Speaker LED Auxiliary Light – Model TS3001R
Warn 10-S Winch with remote mount for solenoid - winch power and in/out switches are mounted inside the truck.
Factor 55 Fairlead
Factor 55 Flatlink - yellow
Proud Rhino Full Suspension kit (includes SYA kit and rods/straps)
Lucky 8 0 sliders
K9 Rack - Standard Full rack
Tactical Rovers Rear bumper with Jerry Can and Tire swing outs.
ARB Compressor CKMA12 (can hookup hose for air tools, tires, etc)
Front ARB Locker RD217
Rear ARB Locker RD218
Tactical Rovers Fuel tank Skid plate
Terrafirma Front Sump Guard
New BFG KO2 x 5 1K miles on them
Black painted 10 Spoke Wheels
Blackout on hood and rocker decals
Safari Snorkel
LR3 Hidden Hitch
Trailer Wiring harness installed with Flat 4 and round 7 sockets.
I bought it built... Build cost was $21-22K alone. All Work was done at LRC Customs and Braddys british in NC.
-7 seats -102k Miles no issues, all maintenance current. -Very nice black interior, seats are not ripped, everything presents well. So usual issues dash is showing the usual cracks on passenger side. -Replaced upgraded Compressor (AMK) -Alignment -New wipers -Upgraded Brass bleeder valve
-New rear Calipers/Pads/Rotors
-TPS & Back up sensors disabled (aftermarket bumpers).
-Brakes, compressor, front EAS valve done
-Falcon off road air line connections
-Dual Jerry can holder
-New awning 180 degree (used twice)
-Front Valve Block replaced (have spare)-Middle Valve block replaced (have spare)-Coolant reservoir replaced-New A-pillar trim (both sides) -Tactical Rovers Dual jerry can holders installed -LED dome lights (CanBus) installed. -Recent oil change -All service current -Front brakes done @ 84K, along with from lower control arms, and a full service. -Includes Gap tool Bluetooth. (great tool)
-New Windshield (due to rock chip)
-New cowl (replaced since windshield was being replaced)
-New Genuine spare programmed key-New northstar AGM battery
-Solar Panel (rack mounted) and charger (keeps battery topped off while running fridge, acc)-No leaks, tears, etc... LR rubber matts throughout.-Clean and Clear title in hand
Expo Trailer
1960s M-416 military trailer for sale.
-34x17 inch tires with aluminum aftermarket rims, 5 on 5 bolt pattern.
-upgraded 3500 lb axle, no brakes
-frame has been POR-15 coated
-hand rolled bed-lining to outside
-tub has been stripped, POR-15 coated and rattle can painted, roll on bed-lining on the inside
-custom larger than stock fenders
-bed has L track aluminum tie down rail system
-lid is custom made, aluminum framed fiber glass with three Yakima cross bars and L channel tie down rails (entire lid is removable)
-Hydraulic assist shocks for lid.
-small ammunition box is bolted to the front of frame for tongue storage
-pintle hitch
-rear and side led marker lights, wired with a 4 pin system
-Smittybilt Overland rooftop tent XL
-two five gallon jerry can mounts, cans included
-11lb aluminum propane tank mount and new tank
-rear hitch mount stabilizing leg
-garage kept for the past 6 years
Tub is solid, Roof top tent is two years old.
Ray_G
Good looking truck-I want your wheels! GLWS
For those that are looking, seller is a standup guy that's a fixture in the LR community.
garrettjmu
Such a solid build. I'm from Fredericksburg and was looking at what LR3 parts I could poach before heading back home to San Diego and came across yours on craigslist... best of luck on the sale!
