Camp Shower...
NewFoundFreedom
So the wife and I have been out on several adventures this year and I must say the Fridge from Sierra Expeditions has been perfect. It makes being out four days and longer without ice really nice. No need to bring three coolers and stock up on ice. It was worth every penny.
Now on to the next problem…A shower. I have been surfin the site a while and have found some good options. Can I get some feedback on this system please?
http://www.helton.com.au/shower units.htm
Has anyone built one from scratch that works well? I am using a five gallon bucket style so there will not be any water container mounted on the rig.
Thanks in advance guys.
NewFound,
I too have labored over ideas to put together a shower system. This is probably the best place to come for that info. That said, search be yer friend! You'll find several large threads about showers, from on-boards, DIY, shelters. The company here is excellent. My problem, too many choices.:jump:
Spunky
I have seen the Helton unit work but never used it, but I think it is a great set up and I will eventually go that route.
Built from "scratch" - otherwise known as Home Brew Fresh Water and Shower System:
It's simple if you've got space for a tank, and there are a number of ways to pull water: hand pump, electric pump, gravity if you're clever, and someone recently brought up the idea of using compressed air to pressurize the system. The world is your playground.
I've already compiled my information, details, and photos at this page:
www.markdstephens.com/frontier/on-board_water_shower.html
Washing feels good, and the ladies like it. Home run.
Good luck!
Mark
I've recently installed a Helton shower kit into the patrol.
I had some problems with it because of my engine's gas conversion and the configuration of my patrol's heater system.
The patrol has a constant flow heater, so the coolant flow is always going through the heater core. I also have an LPG engine conversion which utlises the heater coolant flow to keep the gas mixer warm.
These two things caused some problems with my installation in that it just wasn't heating the water up. I emailed Helton and asked what I had done wrong. The next day he phoned my home number (got my number off the order when I bought it) and told me that he was going to make up some connectors to run my system in series. He sent me over the adaptors and connectors to patch up my other cuts in the hoses (joiners etc) and I'm glad to say it is now working!
double thumbs up for service!
I will say however that I have had to fit a manual hand throttle to the car because at idle there was still not enough flow to heat the water sufficiantly. But my big engine does idle at 500rpms.
I think in warmer weather this system will work a treat. In this cooler weather (winter here at the moment) it's about 10 degree c outside and if I have the flow set too high on the shower I need to run in through the exchanger twice to get it HOT. If I have the flow down to about half it's ok. I think in summer this will not be an issue as even just slightly warmish water in bucket comes out RED HOT.
I've set mine up to run two ways. I have a garden retic tap under the bullbar where I can choose to feed water from the little shower pump that Helton supplied to feed water from a bucket (in case freinds want to use it and supply their own water, or I want to use river water etc) and I can choose to run it direct off my 4Lp self pressure activated tank pump from the rear.
I set up the rear system with just a garden hose fitting so that I can just connect my normal tank water supply hose onto the back. This also means that if I chose to I could for whatever reason run a normaly garden hose straight from a tap into my shower. (maybe a caravan park for instance).
The kit came with a neat little bracket and some air hose fittings (barbs) to connect your inlet and outlet hoses. I got some rubber chair feet from the hardware store that fit perfectly and slipped them on with some chain so that muck and dirt doesn't get into the system when I'm offroad. The heat exchanger came with it's own bracket and even though it's quite small I could not find a neat spot for it under the bonnet, so I just mounted it next tot he fitting under the bull bar. It's well out of the way there and is a perfect fit.
Love my Helton unit. That said they wouldn't be super hard to make your own. If they heat exchanger proper bothers you, buy a loose exchanger and build your own supply/shower head system. Plenty of options at a standard RV supply house as far as shower heads, pumps, etc.
Yeah I was upset that I'd bought the kit when I found out I could have saved $$$ by just buying the exchanger by itself from Helton... But in hindsight I'm glad I did get the kit because the brackets did come in handy and I've now got a dual setup which I think is far better for me in the long run.
Honestly, I like my Zodi. It's not expensive, not glamourous, but does the job and has the flexibility of being converted to built in or, leaving as standalone, you can easily carry to your water source if you can't get your vehicle close. Works with large propane tanks or small ones. 12v or 6 D-cell battery powered pump.
The down side is it does use propane, so you may find fuel scarce depending on where you are. Also it takes up slightly more space than a 50cal ammo box, which may or may not be an issue.
A helton in very high on my priority list after talking Kurt's (cruiseroutfit) ear off about it. He likes his and after 4 days on a dusty trail and no windows in the Jeep I definately could have used a shower or three.
Bobbyjr
