camp/worklights on vehicle??
wanderer-rrorc
after lookin at the SWEET ambulance conversion...I did recall when runnin on the "busses" (squads)...that the sidelights were AWSOME...
but since I gotta go low-pro for the sake of the garage...
what about these mounted to say the sliding door..the back corner and 2 on the backdoors and other side (6 all the way around? heck 3 may do a great job!)..
wonder how well they would light the camp up incase of late/early leaving..noises and just for convenience lights?
http://cgi.ebay.com/ebaymotors/Maxx...5fRVQ5fTrailerQ5fCamperQ5fPartsQ5fAccessories
Maxxima M84400 LED low Profile Cargo Light
Finally! Real usable LED lighting! These lights produce a real light, great for areas where low power draw and maximum light output are important. Solar power, Wind Power, boats, Trailers, Campers and RV's etc.
Very low Profile, easy to mount with included screws, includes small switch in side.
Compact Thin Low Profile Design
Low Profile Surface Mount
Perfect for Interior & Overhead Use
Light Cargo & Compartment Areas
100,000 Hour Rated LED Life
3 Position On/Off Switch
12 Volt DC power, 350 ma
120 Lumen Light output
Three Wire Connection, 7" leads
They could be useful. I have found that a normal work light is way too bright and harsh, and it also sticks out a bit from the vehicle.
I've got 5 flourescent tube lamps inside my van that I hate - these might be a decent replacement..
edit: 3 position switch? on/off/door?
arz
- mo @ pbb
3-position is probably on, off, and probably a tilt sensitive, or ambient light sensitive mode.
Very cool. Im in the process of figuring my camper interior lighting. Those look like the ticket.
I've got a 35 LED "Porch Light" which works fabulously under the awning on Boomer. I had it shipped from Australia a few months back. It draws about 0.2A and puts out enough light to read under the awning at night. My upcoming roof rack build will utilize two tractor utility lights (the ones with the rubber shell) on each side for perimeter lighting. I'm sure they will be a little harsh for the "gather around the campfire and tell stories" atmosphere, but for working around camp, repairs, or setup/teardown, I think they will be perfect.
Spence
MOLLYmaz
