Well hello! New here, have been lurking for a longer time though. I'm based in Europe, where trucks are differently built and categorized, and much stricter limits on GVM apply depending on your driving license. This forum seems to be quite US-centered, but I believe I can find some good advice here as I'm interested in building a truck camper, which is not as popular over here. What's available over here are trucks with a payload typically ranging from 700-1000kg (~1550-2200 lbs). I have experience traveling with smaller vans, having to be somewhat aware of weight limits, and don't immediately see this as an issue. Either way it's semi-off-topic as this isn't meant to turn into some type of vehicle advice thread, maybe I'll make another thread about that at some later point. My main concern right now is with the width of the camper and overhang on the sides.
So for my intended build in case of going down this route, I'd like to take off the tub and mount a pop-up camper box on the back (how best to do that is another thing). The vehicle would be intended for long-term overland travel going wherever, so the camper construction can be permanent, not interested in a slide-in, more space this way. Now, one of the major hurdles presenting itself to me: the trucks I'm looking at here are ~65-70" in width at their widest point (usually measured at the fenders, excluding mirrors) with the majority on the lower end of that. I'm relatively tall, and would strongly prefer to sleep across the width of the camper for obvious space reasons. 200cm (close to 79") is the most common bed lengthover here, and is just right for me. Now, 79" inner width + expected 2,5-3" wall each side (self-build with cold weather insulation) adds up to 84-85" of width on the camper box.
Using an example of one of the vehicles I'm interested in and have found blueprints of, its width at its widest (fenders) is approx 68,5", tub width is 59" and top width, which equals chassis width, is just under 45". Don't know how relevant all these numbers are, but at the least you can compare them to the camper box width numbers mentioned above and imagine how much the camper would visually stick out on the sides.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
How much it overhangs on the sides depends on which number you use (for example, the fender number seems a bit pointless to use as a reference, maybe tub width + a little extra for the sidewalls of the tub, I suppose that's where you'd usually start measuring when speaking of side overhang on a slide-in). Picking non-exact numbers for illustration, 64" is just above the middle of fender and tub width, and 84" is the lower estimate of the camper box width, so that'd be 10" on both sides, could even turn out to be more.
This seems like a lot to me. I've seen plenty pics/videos of other campers and occasionally notice some that also seem to have a lot of side overhang but yeah, as mentioned, seems like a lot to me. I expect to be driving all sorts of roads and generally like to go off-road (not purposely rock crawling or something like that), so I care about how the car drives/handles in those situations. I can already see the total width of the vehicle potentially being a limiting factor on some tighter trails or trying to fit between trees/rocks or whatever, but that's ok. I'm wondering about others' experiences with campers that are much wider than the truck body, or general insight into how this'd affect driving, structural integrity, etc, as well as possible things to look out for/solutions/ideas. Of course also open to comments/talk about other things specific to my situation.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
